Updated on 2025-09-19 GMT+08:00
Configuring a Fault Injection Policy
Fault injection can simulate an invoking failure, which is mainly used for function verification and fault scenario demonstration. This policy applies only to microservices accessed through Java chassis.
Prerequisites
You have created a microservice by referring to Creating a Microservice. After the microservice starts, the service instance is registered with the corresponding service based on the configurations in the YAML file. If the microservice is not created in advance or has been deleted, the microservice is automatically created when the service instance is registered.
Configuring Fault Injection
  1. Log in to CSE.
  2. Choose Exclusive ServiceComb Engines.
  1. Click the target engine.
  2. Choose Microservice Governance.
    • For engines with security authentication disabled, go to 6.
    • For engines with security authentication enabled, if the login user is the user imported in Importing an IAM Account, go to 6. For other users, go to 5.
  3. In the displayed Security Authentication dialog box, enter the account name and password, and click OK.
  4. Click the target microservice. Click Fault Injection.
  5. Click New and select a proper policy. The following table describes the configuration items of fault injection.
    Figure 1 Configuring fault injection (delayed)
    Figure 2 Configuring fault injection (fault)
    Parameter
    Description
    Injection Object
    Microservices for which fault injection is required. You can specify a method for this configuration item.
    Type
    Type of the fault injected to the microservice.
    • Delayed
    • Fault
    Protocol
    Protocol for accessing the microservice when latency or fault occurs.
    • Rest
    • Highway
    Occurrence Probability
    Probability of latency or fault occurrence.
    Delay Time
    Duration of the latency during microservice access. This parameter is required when Type is set to Delayed.
    HTTP Error Code
    HTTP error code during microservice access. This parameter is required when Type is set to Fault. This error code is an HTTP error code.
  6. Click OK.
