Updated on 2025-01-22 GMT+08:00
percentile_approx
This function is used to approximate the pth percentile (including floating-point numbers) of a numeric column within a group.
Syntax
percentile_approx(DOUBLE col, p [, B])
Parameters
Table 1 Parameters
Parameter
Mandatory
Description
col
Yes
Columns with a data type of numeric. If the values are of any other type, NULL is returned.
p
Yes
The value should be between 0 and 1. Otherwise, NULL is returned.
B
Yes
The parameter B controls the accuracy of the approximation, with a higher value of B resulting in a higher level of approximation. The default value is 10000. If the number of non-repeating values in the column is less than B, an exact percentile is returned.
Return Values
The return value is of the DOUBLE type.
Example Code
  • Calculates the 0.5 percentile of all offering inventories (items), with an accuracy of 100. An example command is as follows:
    select PERCENTILE_APPROX(items,0.5,100) from warehouse;
    The command output is as follows:
    | _c0        |
    | 521        |
  • When used with group by, it groups all offerings by warehouse (warehourseId) and returns the 0.5 percentile of the offering inventory (items) in the same group, with an accuracy of 100. An example command is as follows:
    select warehourseId, PERCENTILE_APPROX(items, 0.5, 100) from warehourse group by warehourseId;
    | warehouseId| _c1        |
    | city1    | 499     |
    | city2    | 354     |
    | city3    | 565     |
