Help Center/
Data Lake Insight/
SQL Syntax Reference (Kuala Lumpur Region)/
Spark SQL Syntax Reference/
Built-in Functions/
Mathematical Functions/
pi
Updated on 2025-01-22 GMT+08:00
pi
This function is used to return the value of π.
Syntax
pi()
Return Values
The return value is of the DOUBLE type.
Example Code
The value 3.141592653589793 is returned.
select pi();
Parent topic: Mathematical Functions
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
