Updated on 2024-06-21 GMT+08:00
Managing Bucket Policies
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Besides bucket ACLs, bucket owners can use bucket policies to centrally control access to buckets and objects in buckets.
For more information, see Bucket Policy.
Setting a Bucket Policy
You can call ObsClient.setBucketPolicy to set a bucket policy. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an ObsClient instance.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
obsClient.setBucketPolicy("bucketname", "your policy");
For details about the format (JSON character string) of bucket policies, see the Object Storage Service API Reference.
Obtaining a Bucket Policy
You can call ObsClient.getBucketPolicy to obtain a bucket policy. Sample code is as follows:
String policy = obsClient.getBucketPolicy("bucketname");
Log.i("GetBucketPolicy","\t" + policy);
Deleting a Bucket Policy
You can call ObsClient.deleteBucketPolicy to delete a bucket policy. Sample code is as follows:
obsClient.deleteBucketPolicy("bucketname");
