Updated on 2024-12-03 GMT+08:00
Deleting Versioning Objects
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Deleting a Single Versioning Object
You can call ObsClient.deleteObject to pass a version ID (versionId) to delete an object version.
This example deletes object objectname from bucket bucketname by specifying VersionId.
The example code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
String ak = System.getenv("ACCESS_KEY_ID");
String sk = System.getenv("SECRET_ACCESS_KEY_ID");
String endPoint = "https://your-endpoint";
// Create an instance of ObsClient.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
obsClient.deleteObject("bucketname", "objectname", "versionid");
Deleting Versioning Objects in a Batch
You can call ObsClient.deleteObjects to batch delete specific versions of an object by passing the versionId value of each version to delete.
This example deletes objects objectname1, objectname2, and objectname3 from bucket bucketname in a batch by specifying their version IDs.
DeleteObjectsRequest request = new DeleteObjectsRequest("bucketname");
request.setQuiet(false);
List<KeyAndVersion> toDelete = new ArrayList<KeyAndVersion>();
toDelete.add(new KeyAndVersion("objectname1", "versionid1"));
toDelete.add(new KeyAndVersion("objectname2", "versionid2"));
toDelete.add(new KeyAndVersion("objectname3", "versionid3"));
request.setKeyAndVersions(toDelete.toArray(new KeyAndVersion[toDelete.size()]));
DeleteObjectsResult result = obsClient.deleteObjects(request);
Log.i("DeleteObjects","\t" + result.getDeletedObjectResults());
Log.i("DeleteObjects","\t" + result.getErrorResults());
