Updated on 2024-06-21 GMT+08:00
Setting Bucket Tags
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.setBucketTagging to set bucket tags. Sample code is as follows:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an instance of ObsClient. ObsClient obsClient = new ObsClient(ak, sk, endPoint); BucketTagInfo bucketTagInfo = new BucketTagInfo(); TagSet tagSet = new TagSet(); tagSet.addTag("tag1", "value1"); tagSet.addTag("tag2", "value2"); bucketTagInfo.setTagSet(tagSet); obsClient.setBucketTagging("bucketname", bucketTagInfo);
- A bucket can have up to 10 tags.
- The key and value of a tag can be composed of Unicode characters.
Parent topic: Tag Management
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
