Help Center/
Object Storage Service/
SDK Reference/
Android/
Server-Side Encryption/
Example of Encryption
Updated on 2024-06-21 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Encrypting an Object to Be Uploaded
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); PutObjectRequest request = new PutObjectRequest(); request.setBucketName("bucketname"); request.setObjectKey("objectname"); request.setFile(new File("localfile")); // Set the SSE-C encryption algorithm. SseCHeader sseCHeader = new SseCHeader(); sseCHeader.setAlgorithm(ServerAlgorithm.AES256); // Set the key used to encrypt and decrypt objects in SSE-C mode. This value is a Base64-encoded key. sseCHeader.setSseCKeyBase64("your base64 sse-c key generated by AES-256 algorithm"); request.setSseCHeader(sseCHeader); obsClient.putObject(request);
Decrypting a Downloaded Object
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); GetObjectRequest request = new GetObjectRequest("bucketname", "objectname"); // Set the decryption algorithm to SSE-C. SseCHeader sseCHeader = new SseCHeader(); sseCHeader.setAlgorithm(ServerAlgorithm.AES256); // The key used here must be the one used for uploading the object. sseCHeader.setSseCKeyBase64("your base64 sse-c key generated by AES-256 algorithm"); request.setSseCHeader(sseCHeader); ObsObject obsObject = obsClient.getObject(request); obsObject.getObjectContent().close();
Parent topic: Server-Side Encryption
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
