Updated on 2024-12-03 GMT+08:00
Performing a File-Based Upload
If you have any questions during the development, post them on the Issues page of GitHub. For details about the API parameters and method, see PUT Object.
File-based upload uses local files as the data source of objects. Sample code is as follows:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
    // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
    // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.AccessKeyID,
    secret_access_key: process.env.SecretAccessKey,
    // Replace the example endpoint with the actual one in your case.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
obsClient.putObject({
       Bucket: 'bucketname',
       Key: 'objectname',
       SourceFile: document.getElementById('input-file').files[0]
}, function (err, result) {
       if(err){
              console.error('Error-->' + err);
       }else{
              console.log('Status-->' + result.CommonMsg.Status);
  • Use the SourceFile parameter to specify the to-be-uploaded file (a File or Blob object). For example, on an HTML page, use an input tag whose type is file to specify the to-be-uploaded file: <input type="file" id="input-file"/>.
  • The SourceFile parameter and the Body parameter cannot be used together.
  • The content to be uploaded cannot exceed 5 GB.
