Help Center/
Object Storage Service/
SDK Reference/
BrowserJS/
FAQs/
How Do I Suspend a Resumable Upload Task?
Updated on 2024-04-26 GMT+08:00
The API for resumable upload supports the suspension of upload tasks. The code example is as follows:
// Create an instance of ObsClient. var obsClient = new ObsClient({ // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.AccessKeyID, secret_access_key: process.env.SecretAccessKey, // Replace the example endpoint with the actual one in your case. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); var uploadCheckpoint; obsClient.uploadFile({ Bucket : 'bucketname', Key : 'objectname', SourceFile : document.getElementById('input-file').files[0], PartSize : 9 * 1024 * 1024, ProgressCallback : function(transferredAmount, totalAmount, totalSeconds){ // Obtain the upload progresses. console.log(transferredAmount * 1.0 / totalSeconds / 1024); console.log(transferredAmount * 100.0 / totalAmount); }, ResumeCallback : function(resumeHook, uploadCheckpoint){ // If the upload is suspended after running for three seconds, the API returns an error. setTimeout(function(){ hook.cancel(); }, 3000); // Record a breakpoint. cp = uploadCheckpoint; } }, function(err, result){ console.error('Error-->' + err); // If an error occurs, call the resumable upload API again to continue the upload task. if(err){ obsClient.uploadFile({ UploadCheckpoint : uploadCheckpoint, ProgressCallback : function(transferredAmount, totalAmount, totalSeconds){ // Obtain the upload progresses. console.log(transferredAmount * 1.0 / totalSeconds / 1024); console.log(transferredAmount * 100.0 / totalAmount); }, }, function(err, result){ // Reprocess the callback function. }); }else { console.log('Status-->' + result.CommonMsg.Status); console.log('RequestId-->' + result.CommonMsg.RequestId); } });
Parent topic: FAQs
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
