Updated on 2025-05-16 GMT+08:00
Management Bucket Policies
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Besides bucket ACLs, bucket owners can use bucket policies to centrally control access to buckets and objects in buckets.
For more information, see Bucket Policies.
Setting a Bucket Policy
You can call ObsClient.SetBucketPolicy to set a bucket policy. Sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
try
    SetBucketPolicyRequest request = new SetBucketPolicyRequest
        BucketName = "bucketname",
        Policy = "your policy",
    SetBucketPolicyResponse response = client.SetBucketPolicy(request);
    Console.WriteLine("Set bucket policy response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
For details about the format (JSON character string) of bucket policies, see the Object Storage Service API Reference.
Obtaining a Bucket Policy
You can call ObsClient.GetBucketPolicy to obtain a bucket policy. Sample code is as follows:
try
    GetBucketPolicyRequest request = new GetBucketPolicyRequest
    GetBucketPolicyResponse response = client.GetBucketPolicy(request);
    Console.WriteLine("Get bucket policy response: {0}", response.StatusCode);
    Console.WriteLine("Policy: {0}", response.Policy);
Deleting a Bucket Policy
You can call ObsClient.DeleteBucketPolicy to delete a bucket policy. Sample code is as follows:
try
    DeleteBucketPolicyRequest request = new DeleteBucketPolicyRequest
    DeleteBucketPolicyResponse response = client.DeleteBucketPolicy(request);
    Console.WriteLine("Delete bucket policy response: {0}", response.StatusCode);
