Updated on 2023-12-25 GMT+08:00
Performing a Streaming Download
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Sample code:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Download an object.
try
    GetObjectRequest request = new GetObjectRequest()
        BucketName = "bucketname",
        ObjectKey = "objectname",
    using (GetObjectResponse response = client.GetObject(request))
        string dest = "savepath";
        if (!File.Exists(dest))
           // Write the data streams into the file.
            response.WriteResponseStreamToFile(dest);
        Console.WriteLine("Get object response: {0}", response.StatusCode);
catch (ObsException ex)
   Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
   Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
GetObjectResponse.OutputStream (System.IO.Stream type) is the response stream in GetObjectResponse. You can obtain the object content to a local file or memory via GetObjectResponse.OutputStream. Alternatively, you can call GetObjectResponse.WriteResponseStreamToFile provided by OBS .NET SDK to download the object content to a local file.
Object response streams obtained by GetObjectResponse.OutputStream must be closed explicitly using a GetObjectResponse.OutputStream.Close() call. Otherwise, resource leakage may occur.
