Updated on 2024-12-09 GMT+08:00
Obtaining Download Progress
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call GetObjectRequest.DownloadProgress to register the System.EventHandler callback function to obtain download progress.
This example downloads objectname from bucketname and uses System.EventHandler to monitor the download progress.
The example code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Download an object.
try
    GetObjectRequest request = new GetObjectRequest()
        BucketName = "bucketname",
        ObjectKey = "objectname",
    // Represent the progress by showing how many bytes have been downloaded.
    request.ProgressType = ProgressTypeEnum.ByBytes;
    // Refresh the download progress each time 1 MB data is downloaded.
    request.ProgressInterval = 1024 * 1024;
    // Register the download progress callback function.
    request.DownloadProgress += delegate(object sender, TransferStatus status){
        // Obtain the average download rate.
        Console.WriteLine("AverageSpeed: {0}", status.AverageSpeed / 1024  + "KB/S");
        // Obtain the download progress in percentage.
        Console.WriteLine("TransferPercentage: {0}", status.TransferPercentage);
    using (GetObjectResponse response = client.GetObject(request))
        string dest = "savepath";
        if (!File.Exists(dest))
           // Write the data streams into the file.
            response.WriteResponseStreamToFile(dest);
        Console.WriteLine("Get object response: {0}", response.StatusCode);
catch (ObsException ex)
   Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
   Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
  • You can obtain the download progress when downloading an object in streaming, partial, asynchronous, or resumable mode.
