Website File Hosting
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can perform the following to implement website file hosting:
- Upload the website files to your bucket in OBS as objects and set the MIME type for the objects.
- Set the object ACL to public read.
- Access the objects using a browser.
Sample code:
// Initialize configuration parameters. ObsConfig config = new ObsConfig(); config.Endpoint = "https://your-endpoint"; // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine); string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine); // Create an instance of ObsClient. ObsClient client = new ObsClient(accessKey, secretKey, config); try { //Set the MIME type for an object. PutObjectRequest request = new PutObjectRequest { BucketName = "bucketname", ObjectKey = "test.html", FilePath = "localfile.html",// Path of the local file uploaded. The file name must be specified. CannedAcl = CannedAclEnum.PublicRead,//Set the object ACL to public read. ContentType = "text/html", }; // Upload an object. PutObjectResponse response = client.PutObject(request); Console.WriteLine("put object response: {0}", response.StatusCode); } catch (ObsException ex) { Console.WriteLine("ErrorCode: {0}", ex.ErrorCode); Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage); }
You can use https://bucketname.your-endpoint/test.html in a browser to access files hosted using the sample code.
Feedback
Was this page helpful?
Chatbot
