Updated on 2024-12-09 GMT+08:00
Deleting Website Hosting Settings
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.DeleteBucketWebsite to delete the hosting settings of a bucket.
This example deletes the hosting configuration of bucket bucketname.
The example code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Delete hosting settings.
try
    DeleteBucketWebsiteRequest request = new DeleteBucketWebsiteRequest();
    request.BucketName = "bucketname";
    DeleteBucketWebsiteResponse response = client.DeleteBucketWebsite(request);
    Console.WriteLine("Delete bucket website response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
