Updated on 2023-12-25 GMT+08:00
Example of Encryption
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Encrypting an Object to Be Uploaded
Sample code:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Generate an encryption key.
System.Security.Cryptography.Aes aesEncryption = System.Security.Cryptography.Aes.Create();
aesEncryption.KeySize = 256;
aesEncryption.GenerateKey();
string customerkey = Convert.ToBase64String(aesEncryption.Key);
// Configure the local file to be encrypted before an upload based on the site requirements.
string filePathKms = "D:\\test\\testSseC.zip";
string filePathSseC = "D:\\test\\testSseC.zip";
// Upload the object.
try
    // When uploading an object, use the SSE-KMS algorithm to encrypt the object.
    SseKmsHeader kms = new SseKmsHeader();
    kms.Algorithm = SseKmsAlgorithmEnum.Kms;
    PutObjectRequest request1 = new PutObjectRequest
        BucketName = "bucketname",
        ObjectKey = "objectname1",
        FilePath = filePathKms,
        SseHeader = kms,
    client.PutObject(request1);
    // When uploading an object, use the SSE-C algorithm to encrypt the object.
    PutObjectRequest request2 = new PutObjectRequest
        ObjectKey = "objectname2",
        FilePath = filePathSseC,
        SseHeader = new SseCHeader()
            Algorithm = SseCAlgorithmEnum.Aes256,
            KeyBase64 = customerkey
    client.PutObject(request2);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
Decrypting a To-Be-Download Object
Sample code:
// Download an object.
try
    // When downloading an object, use the SSE-C algorithm to decrypt it.
    GetObjectRequest request = new GetObjectRequest
        // The key used here must be the one used for uploading the object.
        SseCHeader = new SseCHeader()
            KeyBase64 = "customerkey"
    client.GetObject(request);
