Listing Multipart Uploads (SDK for Go)
Function
This API lists ongoing multipart uploads.
Ongoing multipart uploads are the multipart uploads that have been initiated but have not been completed or aborted. A maximum of 1,000 multipart uploads can be returned in a response. If there are over 1,000 ongoing tasks satisfying the list criteria, you need to send more requests to query additional multipart uploads.
Restrictions
- To list multipart uploads, you must be the bucket owner or have the required permission (obs:bucket:ListBucketMultipartUploads in IAM or ListBucketMultipartUploads in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- To list ongoing multipart uploads in a bucket, you must have the ListBucketMultipartUploads permission.
- The bucket owner can grant others the ListBucketMultipartUploads permission.
Method
func (obsClient ObsClient) ListMultipartUploads(input *ListMultipartUploadsInput) (output *ListMultipartUploadsOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for listing multipart uploads. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Prefix |
string |
No |
Explanation: Name prefix that the objects in the multipart uploads to be listed must contain Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned. Restrictions: The value must contain 1 to 1,024 characters. Default value: None |
MaxUploads |
int |
No |
Explanation: Maximum number of listed multipart uploads Restrictions: If the specified value is greater than 1000, only 1,000 multipart uploads are returned. Value range: An integer from 1 to 1000 Default value: 1000 |
Delimiter |
string |
No |
Explanation: Object names are grouped by this parameter, which is often used with Prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes. Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix. Value range: The value must contain 1 to 1,024 characters. Default value: None |
KeyMarker |
string |
No |
Explanation: Object name after which multipart upload listing begins Value range: Value of NextKeyMarker in the response body of the last request Default value: None |
UploadIdMarker |
string |
No |
Explanation: Upload ID after which the multipart upload listing begins Restrictions: This parameter is valid only when used with KeyMarker. If both parameters are specified, multipart uploads with IDs greater than the specified UploadIdMarker for the specified KeyMarker are listed. Value range: The value of NextUploadIdMarker in the response body of the last request Default value: None |
EncodingType |
string |
No |
Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 4. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Bucket |
string |
Value range: The value must contain 3 to 63 characters. |
KeyMarker |
string |
Explanation: Object name after which multipart upload listing begins. This parameter is consistent with that set in the request. Value range: The value must contain 1 to 1,024 characters. Default value: None |
UploadIdMarker |
string |
Explanation: Upload ID after which the multipart upload listing begins, which is consistent with that set in the request Value range: The value must contain 1 to 32 characters. Default value: None |
NextKeyMarker |
string |
Explanation: Object name to start with for the next multipart upload listing request. NextKeyMarker is returned when not all the objects are listed. You can set KeyMarker to this value in the next request to list the remaining multipart uploads. Value range: The value must contain 1 to 1,024 characters. Default value: None |
NextUploadIdMarker |
string |
Explanation: Upload ID to start with for the next multipart upload listing request. This parameter is used together with NextKeyMarker. NextVersionIdMarker is returned when not all the objects are listed. You can set NextKeyMarker to this value in the next request to list the remaining multipart uploads. Value range: The value must contain 1 to 32 characters. Default value: None |
MaxUploads |
int |
Explanation: Maximum number of listed multipart uploads, which is consistent with the same parameter in the request Restrictions: If the specified value is greater than 1000, only 1,000 multipart uploads are returned. Value range: An integer from 1 to 1000 Default value: 1000 |
IsTruncated |
bool |
Explanation: Whether all results are returned in the response Value range:
Prefix |
string |
Explanation: Prefix that the object names in the multipart uploads to be listed must contain. This parameter is consistent with that set in the request. Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned. Restrictions: The value must contain 1 to 1,024 characters. Default value: None |
Delimiter |
string |
Explanation: A character used to group object names in multipart uploads, which is consistent with that set in the request. This parameter is often used with Prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes. Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix. Value range: The value must contain 1 to 1,024 characters. Default value: None |
Uploads |
[]Upload |
Explanation: List of multipart uploads. For details, see Table 5. |
CommonPrefixes |
[]string |
Explanation: List of object name prefixes grouped according to the Delimiter parameter (if specified) Value range: The value must contain 1 to 1,024 characters. Default value: None |
EncodingType |
string |
Parameter |
Type |
Description |
Key |
string |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
UploadId |
string |
Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 1 to 32 characters. Default value: None |
Initiator |
Explanation: Initiator of the multipart upload. For details, see Table 6. |
Owner |
Explanation: Account ID of the object owner. For details, see Table 7. |
StorageClass |
Explanation: Storage class of the object to be uploaded Value range: See Table 8. Default value: None |
Initiated |
time.Time |
Explanation: Time when the multipart upload is initiated Restrictions: The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z. Sample code: time.Now().Add(time.Duration(24) * time.Hour) Default value: None |
Parameter |
Type |
Description |
ID |
string |
Yes if used as a request parameter |
Explanation: Account (domain) ID of the initiator Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
DisplayName |
string |
No |
Explanation: Account name of the initiator Restrictions: The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed. Default value: None |
Parameter |
Type |
Description |
ID |
string |
Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
Constant |
Default Value |
Description |
StorageClassStandard |
STANDARD |
OBS Standard Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
StorageClassWarm |
WARM |
OBS Infrequent Access Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
StorageClassCold |
COLD |
OBS Archive Used for storing rarely accessed (once a year) data. |
Code Examples
This example lists all initiated multipart uploads (that have not yet been completed or aborted) in bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } input := &obs.ListMultipartUploadsInput{} // Specify a bucket name. input.Bucket = "examplebucket" // Specify the maximum number of multipart uploads that can be listed. 10 is used as an example. input.MaxUploads = 10 // List initiated multipart uploads in the bucket. output, err := obsClient.ListMultipartUploads(input) if err == nil { fmt.Printf("List multipart uploads successful with bucket(%s) !\n", input.Bucket) for index, upload := range output.Uploads { fmt.Printf("Upload[%d]-OwnerId:%s, UploadId:%s, Key:%s, Initiated:%s\n", index, upload.Owner.ID, upload.UploadId, upload.Key, upload.Initiated) } return } fmt.Printf("List multipart uploads fail with bucket(%s) !\n", input.Bucket) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
