Obtaining the Logging Configuration of a Bucket (SDK for Go)
Function
This API returns the logging configuration of a bucket.
Restrictions
- To obtain the logging configuration of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketLogging in IAM or GetBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) GetBucketLoggingConfiguration(bucketName string) (output *GetBucketLoggingConfigurationOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
string |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 3. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
StatusCode |
int |
Explanation: HTTP status code Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
RequestId |
string |
Explanation: Request ID returned by the OBS server Default value: None |
ResponseHeaders |
map[string][]string |
Explanation: HTTP response headers Default value: None |
Agency |
string |
Explanation: Name of the IAM agency created by the owner of the target bucket for OBS. You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency. Restrictions: By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located. Default value: None |
TargetBucket |
string |
Explanation: Name of the bucket for storing log files Restrictions:
TargetPrefix |
string |
Explanation: Name prefix for log files stored in the log storage bucket Value range: The value must contain 1 to 1,024 characters. Default value: None |
TargetGrants |
[]Grant |
Explanation: Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 4. |
Parameter |
Type |
Description |
Grantee |
Explanation: Grantee information. For details, see Table 5. |
Permission |
Explanation: Granted permission Value range: See Table 8. Default value: None |
Parameter |
Type |
Description |
Type |
Explanation: Grantee type Value range: See Table 6. Default value: None |
ID |
string |
Explanation: Account (domain) ID of the grantee Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
DisplayName |
string |
Explanation: Account name of the grantee Restrictions:
URI |
Explanation: Authorized user group. For details, see Table 7. |
Constant |
Default Value |
Description |
GranteeGroup |
Group |
User group |
GranteeUser |
CanonicalUser |
Individual user |
Constant |
Default Value |
Description |
PermissionRead |
READ |
Read permission |
PermissionWrite |
WRITE |
Write permission |
PermissionReadAcp |
READ_ACP |
Permission to read ACL configurations |
PermissionWriteAcp |
WRITE_ACP |
Permission to modify ACL configurations |
PermissionFullControl |
FULL_CONTROL |
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. |
Code Examples
This example returns the logging configuration of bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Specify a bucket name. bucketname := "examplebucket" // Obtain the logging configuration of the bucket. output, err := obsClient.GetBucketLoggingConfiguration(bucketname) if err == nil { fmt.Printf("Get bucket(%s)'s BucketLoggingConfiguration successful!\n", bucketname) fmt.Printf("RequestId:%s\n", output.RequestId) fmt.Printf("TargetBucket:%s, TargetPrefix:%s\n", output.TargetBucket, output.TargetPrefix) for index, grant := range output.TargetGrants { fmt.Printf("Grant[%d]-Type:%s, ID:%s, URI:%s, Permission:%s\n", index, grant.Grantee.Type, grant.Grantee.ID, grant.Grantee.URI, grant.Permission) } return } fmt.Printf("Get bucket(%s)'s BucketLoggingConfiguration fail!\n", bucketname) if obsError, ok := err.(obs.ObsError); ok { fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.") fmt.Println(obsError.Error()) } else { fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } } |
Feedback
Was this page helpful?
Chatbot
