Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Obtaining the Lifecycle Configuration of a Bucket (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API returns the lifecycle rules of a bucket.
Restrictions
Method
func (obsClient ObsClient) GetBucketLifecycleConfiguration(bucketName string) (output *GetBucketLifecycleConfigurationOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 3.
err
error
Explanation:
Error messages returned by the API
Table 3 GetBucketLifecycleConfigurationOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
LifecycleRules
[]LifecycleRule
Explanation:
Lifecycle rule information. For details, see Table 4.
Table 4 LifecycleRule
Parameter
Type
Description
ID
string
Explanation:
Lifecycle rule ID
Value range:
The value must contain 1 to 255 characters.
Default value:
None
Prefix
string
Explanation:
Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket.
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg only. If you set Prefix to logs/, the rule applies to the three objects with name starting with logs/. If you leave Prefix blank, the rule applies to all objects in the bucket.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
Status
RuleStatusType
Explanation:
Whether the rule is enabled
Value range:
See Table 5.
Default value:
None
Transitions
[]Transition
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 6.
Restrictions:
This parameter applies only to the current object version.
Expiration
Expiration
Explanation:
Object expiration time. For details, see Table 8.
Restrictions:
NoncurrentVersionTransitions
[]NoncurrentVersionTransition
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 9.
Restrictions:
  • This parameter applies only to noncurrent object versions.
  • Versioning is enabled (or suspended after being enabled) for the bucket.
NoncurrentVersionExpiration
Explanation:
Expiration time of noncurrent object versions. For details, see Table 10.
Restrictions:
CAUTION:
This parameter is not available for parallel file systems.
Transitions, Expiration, NoncurrentVersionTransitions, and NoncurrentVersionExpiration cannot be all left blank.
Table 5 RuleStatusType
Constant
Default Value
Description
RuleStatusEnabled
Enabled
Enabled
RuleStatusDisabled
Disabled
Disabled
Table 6 Transition
Parameter
Type
Description
StorageClass
StorageClassType
Explanation:
Storage class of the object after transition
Restrictions:
  • The Standard storage class is not supported.
  • Restrictions on storage class transitions:
    • Only transitions from the Standard storage class to the Infrequent Access storage class are supported. To transition objects from Infrequent Access to Standard, you must manually do it.
    • Only transitions from the Standard or Infrequent Access storage class to the Archive storage class are supported. To transition objects from Archive to Standard or Infrequent Access, you must restore the archived objects first and then manually transition their storage classes.
    • Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
Value range:
See Table 7.
Default value:
None
Date
time.Time
Explanation:
Date when an object will be transitioned
Restrictions:
The value must conform with the ISO8601 standards and must be at 00:00 (UTC time). For example, 2018-01-01T00:00:00.000Z, indicating only objects that were last modified before that time are transitioned to the specified storage class.
Sample code: time.Now().Add(time.Duration(24) * time.Hour)
Default value:
None
Days
int
Explanation:
Number of days (since the last update was made to the object) after which the lifecycle rule takes effect
Restrictions:
Value range:
0 to (231 – 1), in days
Default value:
None
Table 7 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Table 8 Expiration
Parameter
Type
Mandatory (Yes/No)
Description
Date
time.Time
Yes if this parameter is used as a request parameter and Days is absent
Explanation:
OBS executes the lifecycle rule for objects that were modified before the specified date.
Restrictions:
The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are deleted.
Default value:
None
Days
int
Yes if this parameter is used as a request parameter and Date is absent
Explanation:
Restrictions:
Value range:
1 to (231 – 1), in days
Default value:
None
Table 9 NoncurrentVersionTransition
Parameter
Type
Description
StorageClass
StorageClassType
Explanation:
Storage class of noncurrent object versions after transition
Restrictions:
Value range:
See Table 7.
Default value:
None
NoncurrentDays
int
Explanation:
Number of days an object is noncurrent before the specified rule takes effect
Restrictions:
Value range:
Default value:
None
Table 10 NoncurrentVersionExpiration
Parameter
Type
Mandatory (Yes/No)
Description
NoncurrentDays
int
Yes if used as a request parameter
Explanation:
Restrictions:
Value range:
Default value:
None
Code Examples
This example returns the lifecycle configuration of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint, obs.WithSignature(obs.SignatureObs)/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    // Specify a bucket name.
    bucketname := "examplebucket"
    // Obtain the lifecycle configuration of the bucket.
    output, err := obsClient.GetBucketLifecycleConfiguration(bucketname)
    if err == nil {
        fmt.Printf("Get LifecycleConfiguration successful with bucket:%s!\n", bucketname)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Get LifecycleConfiguration fail with bucket:%s!\n", bucketname)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
