Updated on 2025-05-12 GMT+08:00
Listing Uploaded Parts (SDK for Go)
Function
This API lists the uploaded parts in a specified bucket. This request must contain the multipart upload ID.
You can list the uploaded parts of a specified multipart upload or of all ongoing multipart uploads. A maximum of 1,000 uploaded parts can be returned in a response. If your multipart upload has more than 1,000 parts, you need to send multiple requests to list all uploaded parts. Assembled parts will not be listed.
Restrictions
Method
func (obsClient ObsClient) ListParts(input *ListPartsInput) (output *ListPartsOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
*ListPartsInput
Yes
Explanation:
Input parameters for listing uploaded parts. For details, see Table 2.
Table 2 ListPartsInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
UploadId
string
Yes
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8
Value range:
The value must contain 1 to 32 characters.
Default value:
None
PartNumberMarker
int
No
Explanation:
Part number after which uploaded parts listing begins
Restrictions:
OBS lists only parts with greater numbers than that specified by this parameter.
Default value:
None
MaxParts
int
No
Explanation:
Maximum number of parts that can be listed per page
Restrictions:
If the specified value is greater than 1000, only 1,000 parts are returned.
Value range:
The value ranges from 1 to 1000.
Default value:
1000
EncodingType
string
No
Explanation:
Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key.
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied to Key.
Responses
Table 3 List of returned results
Parameter
Type
Description
output
*ListPartsOutput
Explanation:
Returned results. For details, see Table 4.
err
error
Explanation:
Error messages returned by the API
Table 4 ListPartsOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Bucket
string
Explanation:
Bucket name
Restrictions:
  • A bucket name:
Value range:
The value must contain 3 to 63 characters.
Key
string
Explanation:
Value range:
Default value:
None
UploadId
string
Explanation:
Value range:
The value must contain 32 characters.
Default value:
None
Initiator
Initiator
Explanation:
Initiator of the multipart upload. For details, see Table 5.
Owner
Owner
Explanation:
Owner of the multipart upload, which is consistent with Initiator
StorageClass
StorageClassType
Explanation:
Object storage class
Value range:
See Table 8.
Default value:
None
PartNumberMarker
int
Explanation:
Part number to start with for listing parts, which is consistent with that set in the request
Value range:
A non-negative integer
Default value:
None
NextPartNumberMarker
int
Explanation:
Part number to start with for the next part listing request. NextPartNumberMarker is returned when not all the parts are listed. You can set PartNumberMarker to this value in the next request to list the remaining parts.
Value range:
Default value:
None
MaxParts
int
Explanation:
Maximum number of listed parts that can be listed per page. This parameter is consistent with that set in the request.
Restrictions:
Value range:
Default value:
1000
IsTruncated
bool
Explanation:
Whether all results are returned in the response
Value range:
  • true: Not all results are returned.
  • false: All results are returned.
Default value:
None
Parts
[]Part
Explanation:
List of uploaded parts. For details, see Table 7.
EncodingType
string
Explanation:
Value range:
url
Default value:
Table 5 Initiator
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the initiator
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
DisplayName
string
No
Explanation:
Account name of the initiator
Restrictions:
The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Default value:
None
Table 6 Owner
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Explanation:
Account (domain) ID of the owner
Value range:
Default value:
None
Table 7 Part
Parameter
Type
Description
PartNumber
int
Explanation:
Part number
Value range:
An integer ranging from 1 to 10000
Default value:
None
ETag
string
Explanation:
Part ETag, which is a Base64-encoded, 128-bit MD5 value
Value range:
Default value:
None
Table 8 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Code Examples
This example lists the parts that have been uploaded for a multipart upload.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.ListPartsInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object name (example/objectname as an example).
    input.Key = "example/objectname"
    // Specify the multipart upload ID (00000188677110424014075CC4A77xxx as an example).
    input.UploadId = "00000188677110424014075CC4A77xxx"
    // List the uploaded parts.
    output, err := obsClient.ListParts(input)
    if err == nil {
        fmt.Printf("List part successful with bucket(%s) and object(%s)!\n", input.Bucket, input.Object)
        for index, part := range output.Parts {
            fmt.Printf("Part[%d]-ETag:%s, PartNumber:%d, LastModified:%s, Size:%d\n", index, part.ETag,
                part.PartNumber, part.LastModified, part.Size)
        return
    fmt.Printf("List part fail with bucket(%s) and object(%s)!\n", input.Bucket, input.Object)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
