Help Center/ Object Storage Service/ SDK Reference/ Go/ Objects (SDK for Go)/ Configuring Object Metadata (SDK for Go)
Updated on 2025-05-12 GMT+08:00
Function
Object metadata is a set of name-value pairs that describe the object and is used for object management.
Currently, only the metadata defined by the system is supported.
There are two kinds of metadata: system-controlled metadata and user-controlled metadata. For example, metadata such as Last-Modified is controlled by the system and cannot be modified. You can modify the metadata such as ContentLanguage through the API.
This API sends a HEAD request to configure the metadata of an object in a specified bucket.
Restrictions
  • To configure object metadata, you must be the bucket owner or have the required permission (obs:object:ModifyObjectMetaData in IAM or ModifyObjectMetaData in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • When versioning is enabled for a bucket, you can set metadata for objects of the latest version, but cannot set metadata for objects of historical versions.
  • You cannot set metadata for Archive objects.
Method
func (obsClient ObsClient) SetObjectMetadata(input *SetObjectMetadataInput) (output *SetObjectMetadataOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
Yes
Explanation:
Input parameters for configuring object metadata. For details, see Table 2.
Table 2 SetObjectMetadataInput
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Value range:
The value must contain 3 to 63 characters.
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Object version ID, for example, G001117FCE89978B0000401205D5DC9A
Value range:
The value must contain 32 characters.
Default value:
None
CacheControl
string
No
Explanation:
Cache-Control header in the response. It specifies cache behaviors of the web page when an object is downloaded.
Default value:
None
ContentDisposition
string
No
Explanation:
Content-Disposition header in the response. It specifies the name of the object when it is downloaded.
Default value:
None
ContentEncoding
string
No
Explanation:
Content-Encoding header in the response. It specifies the content encoding format when an object is downloaded.
Default value:
None
ContentLanguage
string
No
Explanation:
Content-Language header in the response. It specifies the content language format when an object is downloaded.
Default value:
None
ContentType
string
No
Explanation:
Content-Type header in the response. It specifies the object file type.
Default value:
None
Expires
string
No
Explanation:
Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded.
Default value:
None
WebsiteRedirectLocation
string
No
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
The request is redirected to object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
StorageClass
StorageClassType
No
Explanation:
Storage class of an object.
Value range:
See Table 3.
Default value:
None
Metadata
map[string]string
No
Explanation:
Custom metadata of the object. You can add a header starting with x-obs-meta- in the request to define metadata. The custom metadata will be returned in the response when you retrieve the object or query the object metadata.
Restrictions:
  • The custom metadata cannot exceed 8 KB. To measure the custom metadata, sum the number of bytes in the UTF-8 encoding of each key and value.
  • The custom metadata keys are case insensitive, but are stored in lowercase in OBS. The key values are case sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
Default value:
None
Table 3 StorageClassType
Constant
Default Value
Description
StorageClassStandard
STANDARD
OBS Standard
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
StorageClassWarm
WARM
OBS Infrequent Access
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed.
StorageClassCold
COLD
OBS Archive
Used for storing rarely accessed (once a year) data.
Responses
Table 4 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 5.
err
error
Explanation:
Error messages returned by the API
Table 5 SetObjectMetadataOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
MetadataDirective
MetadataDirectiveType
Explanation:
Policy for copying the source object's properties
Value range:
See Table 6.
Default value:
None
CacheControl
string
Explanation:
Default value:
None
ContentDisposition
string
Explanation:
Default value:
None
ContentEncoding
string
Explanation:
Default value:
None
ContentLanguage
string
Explanation:
Default value:
None
ContentType
string
Explanation:
Default value:
None
Expires
string
Explanation:
Default value:
None
string
Explanation:
Restrictions:
Default value:
None
StorageClass
StorageClassType
Explanation:
Object storage class. If you do not specify this header, the object inherits the storage class of the bucket.
Value range:
See Table 7.
Default value:
None
Metadata
map[string]string
Explanation:
Restrictions:
Default value:
None
Table 6 MetadataDirectiveType
Constant
Default Value
Description
CopyMetadata
COPY
When copying an object, the object's properties are also copied.
ReplaceMetadata
REPLACE
When copying an object, the object's properties are replaced.
Table 7 StorageClassType
Constant
Default Value
Description
STANDARD
OBS Standard
StorageClassWarm
WARM
StorageClassCold
COLD
OBS Archive
Code Examples
This example configures metadata for object example/objectname in bucket examplebucket. The MIME type of the object is set to image/jpeg, the storage class is set to Archive, and custom metadata is also configured for the object.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint /*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.SetObjectMetadataInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify an object (example/objectname as an example).
    input.Key = "example/objectname"
    // Specify a MIME type (image/jpeg as an example) for the object.
    input.ContentType = "image/jpeg"
    // Specify a storage class (obs.StorageClassCold as an example) for the object.
    input.StorageClass = obs.StorageClassCold
    // Specify custom metadata.
    input.Metadata = map[string]string{"property1": "property-value1", "property2": "property-value2"}
    // Configure metadata for the object.
    output, err := obsClient.SetObjectMetadata(input)
    if err == nil {
        fmt.Printf("Set Object(%s)'s metadata successful with bucket(%s)!\n", input.Key, input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        return
    fmt.Printf("Set Object(%s)'s metadata fail with bucket(%s)!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
