Updated on 2024-11-13 GMT+08:00
Configuring an SDK Proxy (SDK for Node.js)
  1. In the root directory of the project, run the following command to download the proxy-agent dependency.
    npm install --save proxy-agent
  2. Declare and configure proxies in the project.
    const ProxyAgent = require("proxy-agent");
    const proxyAgent = new ProxyAgent(`http://username:password@proxyhost:proxyPort`);
  3. Initialize an ObsClient instance and configure a proxy.
    var obsClient = new ObsClient({
      // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
      // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
      access_key_id: process.env.ACCESS_KEY_ID,
      secret_access_key: process.env.SECRET_ACCESS_KEY,
      // If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
      security_token: process.env.SECURITY_TOKEN,
      // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
      server: "https://obs.ap-southeast-1.myhuaweicloud.com"
      https_agent:proxyAgent,
      http_agent: proxyAgent,
