Updated on 2024-11-13 GMT+08:00
Code Examples (SDK for Node.js)
Object Encryption and Upload
This example uploads object example/objectname to bucket examplebucket and encrypts it using SSE-C.
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function putObject() {
  try {
    const params = {
      // Specify the bucket name.
      Bucket: "examplebucket",
      // Specify an object. example/objectname is used in this example.
      Key: "example/objectname",
      // Specify a text object.
      Body : 'Hello OBS',
      // Specify SSE-C as the encryption algorithm.
      SseC: 'AES256',
      SseCKey: 'your sse-c key generated by AES-256 algorithm'
    // Upload and encrypt the object.
    const result = await obsClient.putObject(params);
    if (result.CommonMsg.Status <= 300) {
      console.log("Put object(%s) under the bucket(%s) successful!", params.Bucket);
      console.log("RequestId: %s", result.CommonMsg.RequestId);
      return;
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", result.CommonMsg.Status);
    console.log("Code: %s", result.CommonMsg.Code);
    console.log("Message: %s", result.CommonMsg.Message);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
putObject();
Object Decryption and Download
This example downloads the encrypted object example/objectname using a stream.
async function getObject() {
  try {
    const params = {
      // Specify the object (example/objectname in this example).
      Key: 'example/objectname',
      // Specify SSE-C as the algorithm.
      SseC: 'AES256',
      // Specify the same key you used for encrypting the object during the upload.
    // Download the encrypted object.
    const result = await obsClient.getObject(params);
      console.log("Get object(%s) under the bucket(%s) successful!", params.Key, params.Bucket);
      console.log('Object Content: %s', result.InterfaceResult.Content);
      return;
  } catch (error) {
    console.log(error);
getObject();
