Updated on 2025-04-02 GMT+08:00
percentile
This function is used to return the numerical value at a certain percentage point within a range of values.
Syntax
percentile(BIGINT col, p)
Parameters
Table 1 Parameters
Parameter
Mandatory
Description
col
Yes
Columns with a data type of numeric. If the values are of any other type, NULL is returned.
p
Yes
The value should be between 0 and 1. Otherwise, NULL is returned.
Return Values
The return value is of the DOUBLE type.
Example Code
  • Calculates the 0.5 percentile of all offering inventories (items). An example command is as follows:
    select percentile(items,0.5) from warehouse;
    The command output is as follows:
    | _c0        |
    | 500.6      |
  • When used with group by, it groups all offerings by warehouse (warehouseId) and returns the 0.5 percentile of the offering inventory (items) in the same group. An example command is as follows:
    select warehouseId, percentile(items, 0.5) from warehourse group by warehouseId;
    | warehouseId| _c1        |
    | city1    | 499.6      |
    | city2    | 354.8      |
    | city3    | 565.7      |
