Updated on 2025-01-22 GMT+08:00
avg
This function is used to return the average value.
Syntax
avg(col), avg(DISTINCT col)
Parameters
Table 1 Parameter
Parameter
Mandatory
Type
Description
col
Yes
All data types
The value can be of any data type and can be converted to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of col is NULL, the column is not involved in calculation.
Example Code
  • Calculates the average number of items across all warehouses. An example command is as follows:
    select avg(items) from warehouse;
    The command output is as follows:
    _c0
    100.0
  • Calculates the average inventory of all items in each warehouse when used with group by. An example command is as follows:
    select warehourseId, avg(items) from warehourse group by warehourseId;
    warehouseId _c1
    city1    155
    city2    101
    city3    194
