Updated on 2025-01-22 GMT+08:00
pow
This function is used to calculate and return the pth power of a.
Syntax
pow(DOUBLE a, DOUBLE p),
power(DOUBLE a, DOUBLE p)
Parameters
Table 1 Parameters
Parameter
Mandatory
Type
Description
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
p
Yes
Return Values
The return value is of the DOUBLE type.
If the value of a or p is NULL, NULL is returned.
Example Code
The value 16 returned.
select pow(2, 4);
The value NULL is returned.
select pow(2, null);
The value 17.429460393524256 is returned.
select pow(2, 4.123456);
