Setting Website Hosting
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.setBucketWebsite to set website hosting for a bucket.
Configuring the Default Homepage and Error Pages
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); WebsiteConfiguration config = new WebsiteConfiguration(); // Configure the default homepage. config.setSuffix("index.html"); // Configure the error pages. config.setKey("error.html"); obsClient.setBucketWebsite("bucketname", config);
Configuring the Redirection Rules
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); WebsiteConfiguration config = new WebsiteConfiguration(); // Configure the default homepage. config.setSuffix("index.html"); // Configure the error pages. config.setKey("error.html"); RouteRule rule = new RouteRule(); Redirect r = new Redirect(); r.setHostName("www.example.com"); r.setHttpRedirectCode("305"); r.setRedirectProtocol(ProtocolEnum.HTTP); r.setReplaceKeyPrefixWith("replacekeyprefix"); rule.setRedirect(r); RouteRuleCondition condition = new RouteRuleCondition(); condition.setHttpErrorCodeReturnedEquals("404"); condition.setKeyPrefixEquals("keyprefix"); rule.setCondition(condition); config.getRouteRules().add(rule); obsClient.setBucketWebsite("bucketname", config);
Configuring Redirection for All Requests
Sample code:
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID. // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); String endPoint = "https://your-endpoint"; // Create an ObsClient instance. ObsClient obsClient = new ObsClient(ak, sk, endPoint); WebsiteConfiguration config = new WebsiteConfiguration(); RedirectAllRequest redirectAll = new RedirectAllRequest(); redirectAll.setHostName("www.example.com"); // Configure the support for both HTTP and HTTPS. redirectAll.setRedirectProtocol(ProtocolEnum.HTTP); config.setRedirectAllRequestsTo(redirectAll); obsClient.setBucketWebsite("bucketname", config);
Feedback
Was this page helpful?
Chatbot
