Updated on 2025-05-16 GMT+08:00
Creating a Bucket (SDK for C)
A bucket is a global namespace of OBS and is a data container. It functions as a root directory of a file system and can store objects.
Sample code:
static void test_create_bucket(obs_canned_acl canned_acl, char *bucket_name)
    obs_status ret_status = OBS_STATUS_BUTT;
    // Create and initialize option.
    obs_options option;
    init_obs_options(&option);
    option.bucket_options.host_name = "<your-endpoint>";
    option.bucket_options.bucket_name = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Set the response callback function.
    obs_response_handler response_handler =
        0, &response_complete_callback
    // Create a bucket. For details about pre-defined ACLs, see the section "Configuring a Bucket ACL (SDK for C)".
    create_bucket(&option, "<bucket ACL>", NULL, &response_handler, &ret_status);
    if (ret_status == OBS_STATUS_OK) {
        printf("create bucket successfully. \n");
    else
        printf("create bucket failed(%s).\n", obs_get_status_name(ret_status));
Bucket names are globally unique. Ensure that the bucket you create is named differently from any other bucket. A bucket name must comply with the following rules:
  • Contains 3 to 63 characters, starts with a digit or letter, and supports only lowercase letters, digits, hyphens (-), and periods (.)
  • Cannot be an IP address.
  • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you create buckets of the same name, no error will be reported and the bucket properties comply with those set in the first creation request.
The example here sets the bucket's ACL to private read and write, storage class to Standard, and location to the default region for the global domain name.
For more information, see Creating a Bucket (SDK for C).
  • During bucket creation, if the endpoint you use corresponds to the default region CN North-Beijing1 (cn-north-1), specifying a region is not a must. If the endpoint you use corresponds to any other region, except the default one, you must set the region to the one that the used endpoint corresponds to. To view the valid regions, see Regions and Endpoints. For example, if the endpoint used for initialization is obs.ap-southeast-1.myhuaweicloud.com, you must set Location to ap-southeast-1 when you create a bucket. Otherwise, status code 400 will be returned.
