Help Center/ Object Storage Service/ SDK Reference/ Go/ Buckets (SDK for Go)/ Obtaining Bucket Tags (SDK for Go)
Updated on 2025-04-03 GMT+08:00
Function
This API returns the tags of a bucket.
Restrictions
Method
func (obsClient ObsClient) GetBucketTagging(bucketName string) (output *GetBucketTaggingOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Responses
Table 2 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 3.
err
error
Explanation:
Error messages returned by the API
Table 3 GetBucketTaggingOutput
Parameter
Type
Description
StatusCode
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
RequestId
string
Explanation:
Request ID returned by the OBS server
Default value:
None
ResponseHeaders
map[string][]string
Explanation:
HTTP response headers
Default value:
None
Tags
[]Tag
Explanation:
Bucket tag list. For details, see Table 4.
Restrictions:
  • A bucket can have a maximum of 10 tags. Each tag can have only one pair of key values.
  • For the same bucket, tag keys must be unique, but tag values can be duplicated or left blank.
Table 4 Tag
Parameter
Type
Mandatory (Yes/No)
Description
Key
string
Yes if used as a request parameter
Explanation:
Tag key
Restrictions:
  • The tag key in the same bucket must be unique.
  • The value of the key can be self-defined or predefined by TMS.
  • The key must contain 1 to 128 characters.
  • Tag keys cannot start or end with a space and cannot contain commas (,), asterisks (*), vertical bars (|), slashes (/), less-than signs (<), greater-than signs (>), equal signs (=), backslashes (\), or ASCII control characters (0x00 to 0x1F). Tag keys and values must be URL encoded before being sent to a server.
  • The value is case-sensitive.
Default value:
None
Value
string
Explanation:
Tag value
Restrictions:
Tag values can be duplicated or left blank.
  • The value must contain 0 to 255 characters.
  • Tag values cannot start or end with a space and cannot contain commas (,), asterisks (*), vertical bars (|), slashes (/), less-than signs (<), greater-than signs (>), equal signs (=), backslashes (\), or ASCII control characters (0x00 to 0x1F). Tag keys and values must be URL encoded before being sent to a server.
Default value:
None
Code Examples
This example returns the tag set associated with bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
package main
import (
    "fmt"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    // Specify a bucket name.
    bucketname := "examplebucket"
    // Obtain bucket tags.
    output, err := obsClient.GetBucketTagging(bucketname)
    if err == nil {
        fmt.Printf("Get bucket(%s)'s tagging configuration successful!\n", bucketname)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        for index, tag := range output.Tags {
            fmt.Printf("Tag[%d]-Key:%s, Value:%s\n", index, tag.Key, tag.Value)
        return
    fmt.Printf("Get bucket(%s)'s tagging configuration fail!\n", bucketname)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
