Help Center/ Object Storage Service/ SDK Reference/ Node.js/ Object Download (SDK for Node.js)/ Downloading an Archive Object (SDK for Node.js)
Updated on 2025-02-26 GMT+08:00
To prolong the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restoration. After a second restore, the validity period of Standard object copies will be prolonged, and you need to pay for storing these copies during the prolonged period.
Function
To download an object in the Archive storage class, you need to restore it first. After an object is restored, a copy of the object is saved in the Standard storage class. By doing so, the object in the Archive storage class and its copy in the Standard storage class co-exist in the bucket. The copy will be automatically deleted once its retention period ends.
This API restores an Archive object in a specified bucket.
Restrictions
  • To restore an Archive object, you must be the bucket owner or have the required permission (obs:object:RestoreObject in IAM or RestoreObject in a bucket policy.) For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
  • To extend the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restoration. After a restoration, the validity period of Standard object copies will be extended, and you need to pay for storing these copies during the extended period.
Method
ObsClient.restoreObject(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
The object specified in ObsClient.restoreObject must be in the Archive storage class. Otherwise, an error is reported.
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
VersionId
string
No
Explanation:
Version ID of the Archive object to restore.
Restrictions:
None
Value range:
The value must contain 32 characters.
Default value:
None. If this parameter is left blank, the latest version of the object is specified.
Days
number
Yes
Explanation:
After an object is restored, a Standard copy is generated for the object. This parameter specifies how long the Standard copy can be retained, that is, the validity period of the restored object.
Restrictions:
None
Value range:
The value ranges from 1 to 30, in days.
Default value:
None
Tier
RestoreTierType
No
Explanation:
Tier of the restoration speed. You can select a suitable tier based on your needs.
Restrictions:
None
Value range:
See Table 2.
Default value:
Standard
Table 2 RestoreTierType
Constant
Default Value
Description
ObsClient.enums.RestoreTierExpedited
Expedited
Objects can be quickly restored from Archive storage within 1 to 5 minutes.
ObsClient.enums.RestoreTierStandard
Standard
Objects can be restored from Archive storage within 3 to 5 hours.
Responses
Table 3 Responses
Type
Description
Table 4
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 4.
Table 4 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 5.
InterfaceResult
Table 6
Explanation:
Results outputted for a successful call. For details, see Table 6.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 5 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 6 BaseResponseOutput
Parameter
Type
Description
RequestId
string
Explanation:
Code Examples
You can call ObsClient.restoreObject to restore an Archive object. Sample code is as follows:
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function downloadColdObject() {
  // Specify the bucket name.
  const bucketName = "examplebucket";
  // Specify the object (example/objectname in this example).
  const objectKey = "example/objectname";
  try {
     // Restore an Archive object.
    const restoreObjectOutput = await obsClient.restoreObject({
      Bucket: bucketName,
      Key: objectKey,
      // Specify how long the restored object will be retained, in days. The value ranges from 1 to 30 (1 this example).
      Days: 1,
      // Specify the restoration speed (obs.RestoreTierExpedited in this example). By default, the object is restored at an expedited speed.
      Tier: obs.enums.RestoreTierExpedited
    if (restoreObjectOutput.CommonMsg.Status > 300) {
      handleMessage(restoreObjectOutput.CommonMsg);
      return;
    // Wait for the object to be restored.
    await sleep(5 * 60);
    // Download the object.
    const getObjectOutput = await obsClient.getObject({
      Bucket: bucketName,
      Key: objectKey,
    if (getObjectOutput.CommonMsg.Status > 300) {
      handleMessage(getObjectOutput.CommonMsg);
      return;
    console.log("Get object(%s) under the bucket(%s) successful!", params.Key, params.Bucket);
    console.log("RequestId: %s", result.CommonMsg.RequestId);
    console.log('Object Content: %s', result.InterfaceResult.Content);
  } catch (error) {
    console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
    console.log(error);
function handleMessage(commonMsg) {
    console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
    console.log("Status: %d", commonMsg.Status);
    console.log("Code: %s", commonMsg.Code);
    console.log("Message: %s", commonMsg.Message);
    console.log("RequestId: %s", commonMsg.RequestId);
function sleep() {
    return new Promise(resolve => {
        setTimeout(resolve, time * 1000);
downloadColdObject();
