SDK Common Results (SDK for Node.js)
After you call an API in an instance of the ObsClient class, a common result object will be returned if no exception is thrown. The following table lists the fields of the object:
Parameter |
Type |
Description |
CommonMsg |
Object |
Common information generated after the API is called, including HTTP status code and error code. |
Status |
Number |
HTTP status code. If the value is smaller than 300, the operation succeeds. Otherwise, the operation fails. |
Code |
String |
Error code returned by the OBS server. If Status is smaller than 300, the value is null. |
Message |
String |
Error description returned by the OBS server. If Status is smaller than 300, the value is null. |
HostId |
String |
Requested Server ID. If Status is smaller than 300, the value is null. |
RequestId |
String |
Request ID returned by the OBS server |
Id2 |
String |
Request ID2 returned by the OBS server |
Indicator |
String |
Detailed error code returned by the OBS server. If Status is smaller than 300, the value is null. |
InterfaceResult |
Object |
Result data generated after the operation is successful. If Status is greater than 300, the value is null. |
RequestId |
String |
Request ID returned by the OBS server. |
Id2 |
String |
Other fields |
For details, see the Response area in the corresponding section. |
Sample code:
// Import the OBS library. // Use npm to install the client. var ObsClient = require('esdk-obs-nodejs'); // Use the source code to install the client. // var ObsClient = require('./lib/obs'); // Create an instance of ObsClient. const obsClient = new ObsClient({ //Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. access_key_id: process.env.ACCESS_KEY_ID, secret_access_key: process.env.SECRET_ACCESS_KEY, //CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. server: 'https://obs.ap-southeast-1.myhuaweicloud.com' }); // Call APIs to perform operations, such as downloading an object. obsClient.getObject({ Bucket : 'bucketname', Key : 'objectname', }, (err, result) => { if(!err){ if(result.CommonMsg.Status < 300){ // Obtain RequestId. console.log('RequestId-->' + result.InterfaceResult.RequestId); // Obtain other parameters. console.log('Content-->' + result.InterfaceResult.Content.toString()); }else{ // Obtain Code and Message. console.log('Code-->' + result.CommonMsg.Code); console.log('Message-->' + result.CommonMsg.Message); } } });
Feedback
Was this page helpful?
Chatbot
