Updated on 2025-02-07 GMT+08:00
Listing Uploaded Parts (SDK for Node.js)
Function
This API lists the uploaded parts in a specified bucket. This request must contain the multipart upload ID.
You can list the uploaded parts of a specified multipart upload or of all ongoing multipart uploads. For each listing request, OBS can list a maximum of 1,000 uploaded parts. If more than 1,000 parts were uploaded for a multipart upload, you need to send more than one request to list all uploaded parts. Assembled parts will not be listed.
Restrictions
  • To list uploaded parts, you must be the bucket owner or have the required permission (obs:object:ListMultipartUploadParts in IAM or ListMultipartUploadParts in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • To learn about the mappings between OBS regions and endpoints, see Regions and Endpoints.
  • A maximum of 1,000 parts can be listed each time. If the upload of a specified ID contains more than 1,000 parts, InterfaceResult.IsTruncated in the response is true, indicating not all parts were listed. In such case, you can use InterfaceResult.NextPartNumberMarker to obtain the start position for the next listing.
Method
ObsClient.listParts(params)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
Bucket
string
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported, and the bucket attributes comply with those set in the first creation request.
Value range:
The value can contain 3 to 63 characters.
Default value:
None
Key
string
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path of the object that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
UploadId
string
Yes
Explanation:
Multipart upload ID, which is generated by initiating a multipart upload.
Restrictions:
None
Value range:
The value must contain 32 characters, for example, 000001648453845DBB78F2340DD460D8.
Default value:
None
PartNumberMarker
number
No
Explanation:
Part number the listing starts from.
Restrictions:
None
Restrictions:
OBS only lists parts with greater numbers than that specified by this parameter.
Default value:
None
MaxParts
number
No
Explanation:
Maximum number of parts that can be listed per page.
Restrictions:
If the specified value is greater than 1000, only 1,000 parts are returned.
Value range:
The value ranges from 1 to 1000.
Default value:
1000
EncodingType
string
No
Explanation:
Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key.
Restrictions:
None
Value range:
url
Default value:
None. If you leave this parameter blank, encoding is not applied.
Responses
Table 2 Responses
Type
Description
Table 3
NOTE:
This API returns a Promise response, which requires the Promise or async/await syntax.
Explanation:
Returned results. For details, see Table 3.
Table 3 Response
Parameter
Type
Description
CommonMsg
ICommonMsg
Explanation:
Common information generated after an API call is complete, including the HTTP status code and error code. For details, see Table 4.
InterfaceResult
Table 5
Explanation:
Results outputted for a successful call. For details, see Table 5.
Restrictions:
This parameter is not included if the value of Status is greater than 300.
Table 4 ICommonMsg
Parameter
Type
Description
Status
number
Explanation:
HTTP status code returned by the OBS server.
Value range:
A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes.
Code
string
Explanation:
Error code returned by the OBS server.
Message
string
Explanation:
Error description returned by the OBS server.
HostId
string
Explanation:
Request server ID returned by the OBS server.
RequestId
string
Explanation:
Request ID returned by the OBS server.
Id2
string
Explanation:
Request ID2 returned by the OBS server.
Indicator
string
Explanation:
Error code details returned by the OBS server.
Table 5 ListMultipartUploadsOutput
Parameter
Type
Description
RequestId
string
Explanation:
Bucket
string
Explanation:
Bucket name
Key
string
Explanation:
UploadId
string
Explanation:
Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8.
Initiator
Initiator
Explanation:
Initiator of the multipart upload. For details, see Table 6.
Owner
Owner
Explanation:
Owner of the multipart upload, which is consistent with an initiator. For details, see Table 7.
StorageClass
StorageClassType
Explanation:
Storage class of the object obtained from assembling parts. For details about storage classes, see Table 8.
PartNumberMarker
number
Explanation:
Part number the listing begins from, which is consistent with that specified in the request.
number
Explanation:
Part number to start with for the next part listing request. This parameter is returned if some parts were not listed. You can set PartNumberMarker to this value in the next request to list the remaining parts.
MaxParts
number
Explanation:
Maximum number of parts that can be listed per page, which is consistent with that specified in the request.
IsTruncated
boolean
Explanation:
Whether all results are returned in the response.
Value range:
  • true: Not all results are returned.
  • false: All results are returned.
Parts
Part[]
Explanation:
List of uploaded parts. For details, see Table 9.
EncodingType
string
Explanation:
Table 6 Initiator
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Yes if used as a request parameter
Explanation:
Account (domain) ID of the initiator
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID? (SDK for Node.js).
Default value:
None
DisplayName
string
No
Explanation:
Account name of the initiator
Restrictions:
The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed.
Default value:
None
Table 7 Owner
Parameter
Type
Mandatory (Yes/No)
Description
ID
string
Explanation:
Account (domain) ID of the owner
Value range:
Default value:
None
DisplayName
string
No
Explanation:
Account name of the owner
Default value:
None
Table 8 StorageClassType
Constant
Default Value
Description
ObsClient.enums.StorageClassStandard
STANDARD
Standard storage class.
Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
ObsClient.enums.StorageClassWarm
WARM
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
ObsClient.enums.StorageClassCold
COLD
Archive storage class.
Used for storing rarely accessed (once a year) data.
Table 9 Part
Parameter
Type
Description
PartNumber
number
Explanation:
Part number
LastModified
string
Explanation:
Time when a part was last modified, in UTC
ETag
string
Explanation:
ETag of a part. It is calculated by encoding the 128-bit MD5 value of the part using Base64.
Size
number
Explanation:
Size of the space occupied by a part
Code Examples
This example lists the parts that have been uploaded for a multipart upload.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
// Import the OBS library.
// Use npm to install the client.
const ObsClient = require("esdk-obs-nodejs");
// Use the source code to install the client.
// var ObsClient = require('./lib/obs');
// Create an instance of ObsClient.
const obsClient = new ObsClient({
  // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
  // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
  access_key_id: process.env.ACCESS_KEY_ID,
  secret_access_key: process.env.SECRET_ACCESS_KEY,
  // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
  // security_token: process.env.SECURITY_TOKEN,
  // Enter the endpoint corresponding to the region where the bucket is located. CN-Hong Kong is used here in this example. Replace it with the one currently in use.
  server: "https://obs.ap-southeast-1.myhuaweicloud.com"
async function listParts() {
    try {
        const params = {
            // Specify the bucket name.
            Bucket: "examplebucket",
            // Specify an object. example/objectname is used in this example.
            Key: "example/objectname",
            // Specify the multipart upload ID (00000188677110424014075CC4A77xxx in this example).
            UploadId: "00000188677110424014075CC4A77xxx",
            // Specify the maximum number of objects to be returned in alphabetic order. The default value is 1000. 100 is used in this example.
            MaxKeys: 100,
        // List uploaded parts.
        const result = await obsClient.listParts(params);
        if (result.CommonMsg.Status <= 300) {
            console.log("List part successful with bucket(%s) and object(%s)!", params.Bucket, params.Key);
            console.log('RequestId: %s', result.CommonMsg.RequestId);
            console.log('Bucket: %s', result.InterfaceResult.Bucket);
            console.log('Key: %s', result.InterfaceResult.Key);
            console.log('UploadId: %s', result.InterfaceResult.UploadId);
            console.log('PartNumberMarker: %s', result.InterfaceResult.PartNumberMarker);
            console.log('NextPartNumberMarker: %s', result.InterfaceResult.NextPartNumberMarker);
            console.log('MaxParts: %s', result.InterfaceResult.MaxParts);
            console.log('IsTruncated: %s', result.InterfaceResult.IsTruncated);
            console.log('StorageClass: %s', result.InterfaceResult.StorageClass);
            console.log('Initiator[ID]: %s', result.InterfaceResult.Initiator['ID']);
            console.log('Owner[ID]: %s', result.InterfaceResult.Owner['ID']);
            for (let i = 0; i < result.InterfaceResult.Parts.length; i++) {
                const part = result.InterfaceResult.Parts[i];
                console.log("Part[%d]-ETag:%s, PartNumber:%d, LastModified:%s, Size:%d",
                    i, part.PartNumber, part.LastModified, part.ETag, part.Size);
            return;
        console.log("An ObsError was found, which means your request sent to OBS was rejected with an error response.");
        console.log("Status: %d", result.CommonMsg.Status);
        console.log("Code: %s", result.CommonMsg.Code);
        console.log("Message: %s", result.CommonMsg.Message);
        console.log("RequestId: %s", result.CommonMsg.RequestId);
    } catch (error) {
        console.log("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.");
        console.log(error);
listParts();
