Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Configuring Logging for a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
This API enables logging for a bucket (source) and configures another bucket (target) to store the log files. When a bucket is created, logging is not enabled by default. You can call this API to enable logging for the bucket. With logging enabled, a log message is generated for each operation on the bucket. Multiple log messages are packed into a file. The bucket for storing log files must be specified when logging is enabled. It can be the bucket logging is enabled for, or any other bucket you have access to. If you specify another bucket for storing logs, the bucket must be in the same region as the logged bucket. You can also configure access to log files and the name prefix of log files.
Restrictions
  • OBS creates log files and uploads them to the bucket. Before enabling logging for a bucket, you need to create an IAM agency to delegate OBS to upload log files to the specified bucket. For details about how to create an agency, see Cloud Service Delegation.
  • To configure logging for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutBucketLogging in IAM or PutBucketLogging in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketLogging(bucketName, logstatus, extensionHeaders)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
logstatus
Logging
No
Explanation:
Logging configuration information For details, see Table 1.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Table 1 Logging
Parameter
Type
Mandatory (Yes/No)
Description
targetBucket
str
No
Explanation:
Name of the bucket for storing log files
Restrictions:
  • This bucket must be in the same region as the bucket with logging enabled.
  • A bucket name:
Default value:
None
targetPrefix
str
No
Explanation:
Name prefix for log files stored in the log storage bucket
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
targetGrants
list of Grant
No
Explanation:
Permission information list of grantees, which defines grantees and their permissions for log files. For details, see Table 2.
Default value:
None
agency
str
Yes when configuring bucket logging
Explanation:
Name of the IAM agency created by the owner of the target bucket for OBS.
You can select an existing IAM agency or create one. For details about how to create an agency, see Creating an IAM Agency.
Restrictions:
By default, the IAM agency only requires the PutObject permission to upload logs to the target bucket. If default encryption is enabled for the target bucket, the agency also requires the KMS Administrator permission in the region where the target bucket is located.
Default value:
None
Table 2 Grant
Parameter
Type
Mandatory (Yes/No)
Description
grantee
Grantee
Yes
Explanation:
Grantee information. For details, see Table 3.
permission
str
Yes
Explanation:
Granted permission
Value range:
See Table 4.
Default value:
None
delivered
bool
No
Explanation:
Whether the bucket ACL is applied to all objects in the bucket
Value range:
True: The bucket ACL is applied to all objects in the bucket.
False: The bucket ACL is not applied to all objects in the bucket.
Default value:
False
Table 3 Grantee
Parameter
Type
Mandatory (Yes/No)
Description
grantee_id
str
Yes if group is left blank.
Explanation:
Account (domain) ID of the grantee.
Value range:
To obtain an account ID, see Obtaining the Account ID.
Default value:
None
grantee_name
str
No
Explanation:
Username of the grantee.
Restrictions:
  • Starts with a letter. Contains 6 to 32 characters.
  • Contains only letters, digits, hyphens (-), and underscores (_).
Default value:
None
group
str
Yes if grantee_id is left blank.
Explanation:
Authorized user group
Value range:
See Table 5.
Default value:
None
The authorized entity can be an individual user or a user group. grantee_id and grantee_name must be used together and they cannot be used with group.
Table 4 Permission
Constant
Description
READ
Read permission
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
WRITE
Write permission
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
Such permission for an object is not applicable.
READ_ACP
Permission to read ACL configurations
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for the bucket or object permanently.
WRITE_ACP
Permission to modify ACL configurations
A grantee with this permission can update the ACL of a bucket or object.
A grantee with this permission can modify the ACL, thus obtaining full access permissions.
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Table 5 Group
Constant
Description
ALL_USERS
All users
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 6 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
Code Examples
This example configures logging for bucket examplebucket and store log files in bucket targetbucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
from obs import ObsClient
from obs import Grantee
from obs import Logging
from obs import Permission
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    # Authorize the account ID (domain_id) of a user to read the bucket logs.
    grantee1 = Grantee(grantee_id='domain_id')
    grant1 = Grant(grantee=grantee1, permission=Permission.READ)
    grantList = [grant1]
    # Specify a bucket name for storing generated log files.
    targetBucket = "targetBucket"
    # Specify an object prefix, indicating the path for storing log files.
    targetPrefix = 'test/'
    # Specify an agency name.
    agency = 'your agency'
    # Specify the logging configuration information.
    logstatus = Logging(targetBucket=targetBucket, targetPrefix=targetPrefix, grantList=grantList, agency=agency)
    bucketName = "examplebucket"
    # Configure logging for the bucket.
    resp = obsClient.setBucketLogging(bucketName=bucketName , logstatus=logstatus )
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Set Bucket Logging Succeeded')
        print('requestId:', resp.requestId)
    else:
        print('Set Bucket Logging Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
