Help Center/ Object Storage Service/ SDK Reference/ Python/ Bucket-Related APIs (SDK for Python)/ Obtaining the Versioning Status of a Bucket (SDK for Python)
Updated on 2025-05-09 GMT+08:00
Function
You can enable versioning to automatically maintain previous versions of an object. When versioning is enabled, you can access earlier versions of an object to recover your data in the event of accidental actions or application failures. For more information, see Versioning.
This API obtains the versioning status of a bucket.
Restrictions
Method
ObsClient.getBucketVersioning(bucketName, extensionHeaders)
Request Parameters
Parameter
Type
Mandatory (Yes/No)
Description
bucketName
str
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Default value:
None
extensionHeaders
dict
No
Explanation:
Extension headers.
Value range:
See User-defined Header (SDK for Python).
Default value:
None
Responses
Type
Description
GetResult
Explanation:
SDK common results
Table 1 GetResult
Parameter
Type
Description
status
int
Explanation:
HTTP status code
Value range:
A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
reason
str
Explanation:
Reason description.
Default value:
None
errorCode
str
Explanation:
Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
errorMessage
str
Explanation:
Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank.
Default value:
None
requestId
str
Explanation:
Request ID returned by the OBS server
Default value:
None
indicator
str
Explanation:
Error indicator returned by the OBS server.
Default value:
None
hostId
str
Explanation:
Requested server ID. If the value of status is less than 300, this parameter is left blank.
Default value:
None
resource
str
Explanation:
Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank.
Default value:
None
header
list
Explanation:
Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header.
Default value:
None
body
object
Explanation:
Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python).
Default value:
None
GetResult.body Type
Description
str
Explanation:
Versioning status of the bucket
Value range:
  • Enabled
  • Suspended
Default value:
None
Code Examples
This example returns the versioning status of bucket examplebucket.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
from obs import ObsClient
import os
import traceback
# Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage.
# Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
ak = os.getenv("AccessKeyID")
sk = os.getenv("SecretAccessKey")
# (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables.
# security_token = os.getenv("SecurityToken")
# Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use.
server = "https://obs.ap-southeast-1.myhuaweicloud.com"
# Create an obsClient instance.
# If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance.
obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server)
try:
    bucketName="examplebucket"
    # Obtain the bucket's versioning status.
    resp = obsClient.getBucketVersioning(bucketName)
    # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails.
    if resp.status < 300:
        print('Get Bucket Versioning Succeeded')
        print('requestId:', resp.requestId)
        print('status:', resp.body)
    else:
        print('Get Bucket Versioning Failed')
        print('errorCode:', resp.errorCode)
        print('errorMessage:', resp.errorMessage)
except:
    print(traceback.format_exc())
