Help Center/
Object Storage Service/
SDK Reference/
Python/
Object-Related APIs (SDK for Python)/
Obtaining the Upload Progress (SDK for Python)
Updated on 2024-11-26 GMT+08:00
You can query the upload progress when uploading an object in streaming, file-based, multipart, appendable, or resumable mode.
This example configures a callback function to obtain the object upload progress.
Sample code is as follows:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 |
from obs import ObsClient import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. Here uses CN-Hong Kong as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) # Obtain the upload progress. def callback(transferredAmount, totalAmount, totalSeconds): # Obtain the average upload rate (KB/s). print(transferredAmount * 1.0 / totalSeconds / 1024) # Obtain the upload progress in percentage. print(transferredAmount * 100.0 / totalAmount) try: bucketName = "examplebucket" # Specify an object name (the name displayed after the file is uploaded to the bucket). objectKey = "objectname" # Specify the full path of the file to be uploaded, for example, aa/bb.txt. file_path = 'localfile' # Perform the file-based upload. resp = obsClient.putFile(bucketName, objectKey, file_path, progressCallback=callback) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Put File Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) print('versionId:', resp.body.versionId) print('storageClass:', resp.body.storageClass) else: print('Put File Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Put File Failed') print(traceback.format_exc()) |
Parent topic: Object-Related APIs (SDK for Python)
Feedback
Was this page helpful?
The system is busy. Please try again later.
Chatbot
