Listing Multipart Uploads (SDK for Python)
Function
This API lists ongoing multipart uploads.
Ongoing multipart uploads are the multipart uploads that have been initiated but have not been completed or aborted. A maximum of 1,000 multipart uploads can be returned in a response. If there are over 1,000 ongoing tasks satisfying the list criteria, you need to send more requests to query additional multipart uploads.
Restrictions
- To list multipart uploads, you must be the bucket owner or have the required permission (obs:bucket:ListBucketMultipartUploads in IAM or ListBucketMultipartUploads in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- To list ongoing multipart uploads in a bucket, you must have the ListBucketMultipartUploads permission.
- By default, only the bucket owner and multipart upload initiator have this permission. The bucket owner can grant others the ListBucketMultipartUploads permission.
Method
ObsClient.listMultipartUploads(bucketName, multipart, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucket |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
multipart |
No |
Explanation: Request parameters for listing multipart uploads. For details, see Table 2. |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
encoding_type |
str |
No |
Explanation: Encoding type for Key in the response. If Key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode Key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Parameter |
Type |
Description |
prefix |
str |
No |
Explanation: Name prefix that the objects in the multipart uploads to be listed must contain Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned. Restrictions: The value must contain 1 to 1,024 characters. Default value: None |
max_uploads |
int or str |
No |
Explanation: Maximum number of listed multipart uploads Restrictions: If the specified value is greater than 1000, only 1,000 multipart uploads are returned. Value range: An integer from 1 to 1000 Default value: 1000 |
delimiter |
str |
No |
Explanation: Object names are grouped by this parameter, which is often used with prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefix. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefix. Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefix with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefix with abcd as the prefix, and bbcde is grouped separately into another CommonPrefix with bbcd as the prefix. Value range: The value must contain 1 to 1,024 characters. Default value: None |
key_marker |
str |
No |
Explanation: Object name after which the multipart upload listing begins Value range: The value of nextKeyMarker in the response body of the last request Default value: None |
upload_id_marker |
str |
No |
Explanation: Upload ID after which the multipart upload listing begins Restrictions: This parameter is valid only when used with key_marker. If both parameters are specified, multipart uploads with IDs greater than the specified uploadIdMarker for the specified keyMarker are listed. Value range: The value of nextUploadIdMarker in the response body of the last request Default value: None |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
GetResult.body Type |
Description |
Explanation: Response to the request for listing multipart uploads |
Parameter |
Type |
Description |
bucket |
str |
keyMarker |
str |
Explanation: Object name after which the multipart upload listing begins, which is consistent with that set in the request. Value range: The value must contain 1 to 1,024 characters. Default value: None |
uploadIdMarker |
str |
Explanation: Upload ID after which the multipart upload listing begins, which is consistent with that set in the request Value range: The value must contain 1 to 32 characters. Default value: None |
nextKeyMarker |
str |
Explanation: Object name to start with for the next multipart upload listing request. nextKeyMarker is returned when not all the objects are listed. You can set key_marker to this value in the next request to list the remaining multipart uploads. Value range: The value must contain 1 to 1,024 characters. Default value: None |
nextUploadIdMarker |
str |
Explanation: Upload ID to start with for the next multipart upload listing request. This parameter is used together with nextKeyMarker. nextUploadIdMarker is returned when not all the objects are listed. You can set upload_id_marker to this value in the next request to list the remaining multipart uploads. Value range: The value must contain 1 to 32 characters. Default value: None |
maxUploads |
int |
Explanation: Maximum number of listed multipart uploads, which is consistent with that in the request Restrictions: If the specified value is greater than 1000, only 1,000 multipart uploads are returned. Value range: An integer from 1 to 1000 Default value: 1000 |
isTruncated |
bool |
Explanation: Whether all results are returned in the response Value range:
prefix |
str |
Explanation: Prefix that the object names in the multipart uploads to be listed must contain. This parameter is consistent with that set in the request. Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you specify logs/ as the prefix, the multipart uploads of logs/day1, logs/day2, and logs/day3 will be returned. If you leave this parameter blank, all multipart uploads in the bucket will be returned. Restrictions: The value must contain 1 to 1,024 characters. Default value: None |
delimiter |
str |
Explanation: A character used to group object names in multipart uploads, which is consistent with that set in the request. This parameter is often used with prefix. If a prefix is specified, objects with the same string from the prefix to the first delimiter are grouped into one CommonPrefixes. If no prefix is specified, objects with the same string from the first character to the first delimiter are grouped into one CommonPrefixes. Assume that a bucket has objects abcd, abcde, and bbcde in it. If delimiter is set to d and prefix is set to a, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix. If only delimiter is set to d, objects abcd and abcde are grouped into a CommonPrefixes with abcd as the prefix, and bbcde is grouped separately into another CommonPrefixes with bbcd as the prefix. Value range: The value must contain 1 to 1,024 characters. Default value: None |
upload |
list of Upload |
Explanation: List of multipart uploads. For details, see Table 7. Default value: None |
commonPrefixs |
list of CommonPrefix |
Explanation: List of object name prefixes grouped according to the delimiter parameter (if specified) Value range: The value must contain 1 to 1,024 characters. Default value: None |
encoding_type |
str |
Explanation: Encoding type for key in the response. If key in the response contains control characters that are not supported by the XML 1.0 standard, you can specify this parameter to encode key. Value range: url Default value: None. If you leave this parameter blank, encoding is not applied to Key. |
Parameter |
Type |
Description |
key |
str |
Explanation: Name of the object to be uploaded. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
uploadId |
str |
Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8 Value range: The value must contain 1 to 32 characters. Default value: None |
initiator |
Explanation: Initiator of the multipart upload. For details, see Table 9. Default value: None |
owner |
Explanation: Owner of the multipart upload, which is consistent with initiator. For details, see Table 10. Default value: None |
storageClass |
str |
Explanation: Storage class of the object to be uploaded Value range: See Table 11. Default value: None |
initiated |
str |
Explanation: Time when the multipart upload is initiated Restrictions: The time must be in the ISO8601 format, for example, 2018-01-01T00:00:00.000Z. Sample code: DateTime(year=2023, month=9, day=12) Default value: None |
Parameter |
Type |
Description |
prefix |
str |
Parameter |
Type |
Description |
id |
str |
Yes if used as a request parameter |
Explanation: Account (domain) ID of the initiator Value range: To obtain an account ID, see Obtaining the Account ID. Default value: None |
name |
str |
No if used as a request parameter |
Explanation: Account name of the initiator Restrictions: The account name can contain 6 to 32 characters and must start with a letter. Only letters, digits, hyphens (-), and underscores (_) are allowed. Default value: None |
Parameter |
Type |
Description |
owner_id |
str |
Explanation: Account (domain) ID of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python) Default value: None |
owner_name |
str |
Explanation: Account name of the owner Value range: To obtain the account ID, see How Do I Get My Account ID and IAM User ID? (SDK for Python) Default value: None |
Parameter |
Type |
Description |
STANDARD |
Standard storage class |
Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
WARM |
Infrequent Access storage class |
Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
COLD |
Archive storage class |
Explanation: Used for storing rarely accessed (once a year) data. |
Code Examples
This example lists multipart uploads in a bucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 |
from obs import ObsClient from obs import ListMultipartUploadsRequest import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: bucketName = "examplebucket" # Specify the prefix that the object names in the multipart uploads to be listed must contain. prefix = 'prefix' # Specify the maximum number (10 as an example) of returned multipart uploads. The value ranges from 1 to 1,000. If the value is not in this range, 1,000 is returned by default. max_uploads = 10 # Specify request parameters for listing multipart uploads. multipart = ListMultipartUploadsRequest(prefix=prefix, max_uploads=max_uploads) # List multipart uploads in a bucket. resp = obsClient.listMultipartUploads(bucketName, multipart, encoding_type='url') # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('List Multipart Uploads Succeeded') print('requestId:', resp.requestId) print('bucket:', resp.body.bucket) print('prefix:', resp.body.prefix) print('maxUploads:', resp.body.maxUploads) print('isTruncated:', resp.body.isTruncated) index = 1 for upload in resp.body.upload: print('upload [' + str(index) + ']') print('key:', upload.key) print('uploadId:', upload.uploadId) print('storageClass:', upload.storageClass) print('initiated:', upload.initiated) print('owner_id:', upload.owner.owner_id) print('owner_name:', upload.owner.owner_name) index += 1 else: print('List Multipart Uploads Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('List Multipart Uploads Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
