How Do I Specify Content-SHA256? (SDK for Python)
The x-obs-content-sha256 header can be carried during object or part upload.
The value of this header is a hexadecimal representation of the SHA-256 value of the request body calculated using Hex(SHA256Hash(<payload>). The server verifies the calculated value for integrity check. This might affect the performance but is still recommended for security purposes.
The code example for object upload is as follows:
# -*- coding:utf-8 -*- # This example uploads a file with content-sha256 specified. from obs import ObsClient import os import traceback import hashlib # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair from the management console by referring to https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Calculate SHA256 of the file. def getSha256(file_path): # Read the file content in binary mode. with open(file_path, 'rb') as f: # Create an SHA256 hash object. sha256_hash = hashlib.sha256() # Read the file content cyclically and update the hash value. while True: data = f.read(65536) # Read 64 KB each time. if not data: break sha256_hash.update(data) # Return the hexadecimal representation of the hash value. sha256 = sha256_hash.hexdigest() f.close() return sha256 # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) bucketName = 'examplebucket' objectKey = 'example/objectname1' file_path = 'D:\\example.txt' # Specify the user-defined header. extensionHeaders = {'x-obs-content-sha256': getSha256(file_path)} try: # Upload a file. resp = obsClient.putFile(bucketName, objectKey, file_path, extensionHeaders=extensionHeaders) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Put File Succeeded') print('requestId:', resp.requestId) print('etag:', resp.body.etag) print('versionId:', resp.body.versionId) else: print('Put File Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print(traceback.format_exc())
Python SDK supports both MD5 and SHA256 for integrity check, though SHA256 is recommended for higher security.
Feedback
Was this page helpful?
Chatbot
