NGINX仪表盘模板
日志服务支持采集NGINX日志,并进行多维度分析。云日志服务支持日志采集向导一站式采集NGINX日志,并为NGINX日志配置结构化和仪表盘。Nginx (engine x) 是一个高性能的HTTP和反向代理web服务器,同时也提供了IMAP/POP3/SMTP服务。
NGINX仪表盘模板支持查看NGINX秒级监控、查看NGINX访问中心和查看NGINX监控中心。
前提条件
- 已采集NGINX日志。
- 日志配置结构化,详情请参见设置云端结构化解析日志。
查看NGINX秒级监控
- 登录云日志服务控制台,进入“日志管理”页面。
- 在左侧导航栏中选择“仪表盘”。
- 在仪表盘模板下方,选择“NGINX仪表盘模板 > NGINX秒级监控”,查看图表详情。
- QPS图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT(TIME_CEIL(__time,'PT1S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , COUNT(*) as QPS from log group by _time_
- 成功率图表所关联的查询分析语句如下所示:
select __time,round(CASE WHEN "成功率" > 0 THEN "成功率" else 0 end,2) as "成功率" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1) as '成功率' from log group by __time)
- 延迟图表所关联的查询分析语句如下所示:
select __time,round(CASE WHEN "访问延迟" > 0 THEN "访问延迟" else 0 end,2) as "访问延迟",round(CASE WHEN "Upstream延迟" > 0 THEN "Upstream延迟" else 0 end,2) as "Upstream延迟" from (select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time, avg(request_time)* 1000 as '访问延迟',avg(upstream_response_time)* 1000 as 'Upstream延迟' from log group by __time)
- 流量图表所关联的查询分析语句如下所示:
select TIME_FORMAT(TIME_CEIL(__time,'PT5S'),'yyyy-MM-dd HH:mm:ss','+08:00') as __time , sum("request_length") as "请求流量", sum("body_bytes_sent") as "返回body流量" group by __time
- 状态码图表所关联的查询分析语句如下所示:
select t.t as "time", CASE WHEN a."2XX" IS NOT NULL THEN CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX", CASE WHEN b."3XX" IS NOT NULL THEN CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX", CASE WHEN c."4XX" IS NOT NULL THEN CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX", CASE WHEN d."5XX" IS NOT NULL THEN CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX", CASE WHEN e."其他" IS NOT NULL THEN CAST(e."其他" AS BIGINT) ELSE 0 END as "其他" from (select TIME_CEIL(__time,'PT5S') as t from log group by t order by t asc ) t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "status" >= 200 and "status" < 300 group by t order by t asc ) a on t.t =a.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "status" >= 300 and "status" < 400 group by t order by t asc) b on t.t =b.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "status" >= 400 and "status" < 500 group by t order by t asc) c on t.t =c.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "status" >= 500 and "status" < 600 group by t order by t asc) d on t.t =d.t left join (select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "status" < 200 or "status" >= 600 group by t order by t asc) e on t.t =e.t
- 后端响应码图表所关联的查询分析语句如下所示:
select t.t as "time", CASE WHEN a."2XX" IS NOT NULL THEN CAST(a."2XX" AS BIGINT) ELSE 0 END as "2XX", CASE WHEN b."3XX" IS NOT NULL THEN CAST(b."3XX" AS BIGINT) ELSE 0 END as "3XX", CASE WHEN c."4XX" IS NOT NULL THEN CAST(c."4XX" AS BIGINT) ELSE 0 END as "4XX", CASE WHEN d."5XX" IS NOT NULL THEN CAST(d."5XX" AS BIGINT) ELSE 0 END as "5XX", CASE WHEN e."其他" IS NOT NULL THEN CAST(e."其他" AS BIGINT) ELSE 0 END as "其他" from ( select TIME_CEIL(__time,'PT5S') as t from log group by t order by t asc ) t left join( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "2XX" from log WHERE "upstream_status" >= 200 and "upstream_status" < 300 group by t order by t asc) a on t.t = a.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "3XX" from log WHERE "upstream_status" >= 300 and "upstream_status" < 400 group by t order by t asc) b on t.t =b.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "4XX" from log WHERE "upstream_status" >= 400 and "upstream_status" < 500 group by t order by t asc) c on t.t =c.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "5XX" from log WHERE "upstream_status" >= 500 and "upstream_status" < 600 group by t order by t asc) d on t.t =d.t left join ( select TIME_CEIL(__time,'PT5S') as t , CAST(COUNT(1) as VARCHAR) as "其他" from log WHERE "upstream_status" < 200 or "upstream_status" >= 600 group by t order by t asc) e on t.t =e.t
查看NGINX访问中心
- 在仪表盘模板下方,选择“NGINX仪表盘模板 > NGINX访问中心”,查看图表详情。
- PV对比昨日图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 86400) as diff from (select count(1) as "pv" from log))
- PV对比上周图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "pv" , 604800) as diff from (select count(1) as "pv" from log))
- UV对比昨日图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 86400) as diff from (select APPROX_COUNT_DISTINCT(my_remote_addr) as "uv" from log))
- UV对比上周图表所关联的查询分析语句如下所示:
select diff[1] as "total", round((diff[1] - diff[2]) / diff[2] * 100, 2) as inc from(select compare( "uv" , 604800) as diff from (select APPROX_COUNT_DISTINCT(my_remote_addr) as "uv" from log))
- 访问量PV分布(中国)图表所关联的查询分析语句如下所示:
select ip_to_province(remote_addr) as province, count(1) as pv where IP_TO_COUNTRY (remote_addr) = '中国' group by province HAVING province not in ('','保留地址','*')
- 访问量PV分布(世界)图表所关联的查询分析语句如下所示:
SELECT ip_to_country(remote_addr) as country,COUNT(1) as PV GROUP BY country HAVING country not in ('','保留地址','*')
- 访问量UV分布(中国)图表所关联的查询分析语句如下所示:
select ip_to_province(remote_addr) as province, APPROX_COUNT_DISTINCT(remote_addr) as UV where IP_TO_COUNTRY (remote_addr) = '中国' group by province HAVING province not in ('','保留地址','*')
- 访问量UV分布(世界)图表所关联的查询分析语句如下所示:
select ip_to_country(remote_addr) as country, APPROX_COUNT_DISTINCT(remote_addr) as uv group by country HAVING country not in ('','保留地址','*')
- 平均时延分布(中国)图表所关联的查询分析语句如下所示:
SELECT province,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)"FROM (SELECT ip_to_province(remote_addr) as province,avg(request_time) * 1000 AS "平均延迟(ms)"WHERE IP_TO_COUNTRY (remote_addr) = '中国'GROUP BY province HAVING province not in ('','保留地址','*'))
- 平均时延分布(世界)图表所关联的查询分析语句如下所示:
SELECT country,round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 2 ) AS "平均延迟(ms)"FROM (SELECT ip_to_country(remote_addr) as country,avg(request_time) * 1000 AS "平均延迟(ms)" GROUP BY country HAVING country not in ('','保留地址','*'))
- 今日PV/UV图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV, APPROX_COUNT_DISTINCT(my_remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR group by _time_ order by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
- 7日PV/UV图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV from log WHERE __time <= CURRENT_TIMESTAMP and __time >= DATE_TRUNC( 'DAY',(CURRENT_TIMESTAMP + INTERVAL '8' HOUR)) - INTERVAL '8' HOUR - INTERVAL '7' DAY group by _time_ order by _time_ ) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
- 区域访问TOP10(省份)图表所关联的查询分析语句如下所示:
select ip_to_province(remote_addr) as "province", count(1) as "访问次数" group by "province" HAVING "province" <> '-1' order by "访问次数" asc limit 10
- 区域访问TOP10(城市)图表所关联的查询分析语句如下所示:
select ip_to_city(remote_addr) as "city", count(1) as "访问次数" group by "city" HAVING "city" <> '-1' order by "访问次数" asc limit 10
- Host访问TOP10图表所关联的查询分析语句如下所示:
select host as "Host", count(1) as "PV" group by "Host" order by "PV" asc limit 10
- UserAgent访问TOP10图表所关联的查询分析语句如下所示:
select http_user_agent as "UserAgent", count(1) as "PV" group by "UserAgent" order by "PV" asc limit 10
- 设备占比(终端)图表所关联的查询分析语句如下所示:
select case when regexp_like(lower(http_user_agent), 'iphone|ipod|android|ios') then '移动端' else 'PC端' end as type , count(1) as total group by type
- 设备占比(系统)图表所关联的查询分析语句如下所示:
select case when regexp_like(lower(http_user_agent), 'iphone|ipod|ios') then 'IOS' when regexp_like(lower(http_user_agent), 'android') then 'Android' else 'other' end as type , count(1) as total group by type HAVING type != 'other'
- TOP URL图表所关联的查询分析语句如下所示:
select request_uri , count(1) as PV, APPROX_COUNT_DISTINCT(remote_addr) as UV, round(sum( case when status < 400 then 1 else 0 end ) * 100.0 / count(1), 2) as "访问成功率" group by request_uri ORDER by PV desc
- TOP 访问IP图表所关联的查询分析语句如下所示:
select remote_addr as "来源IP",ip_to_country(remote_addr) as "国家",ip_to_province(remote_addr) as "省份",ip_to_city(remote_addr) as "城市",ip_to_provider(remote_addr) as "运营商",count(1) as "PV",http_user_agent as "UserAgent采样",request_uri as "URL采样" group by remote_addr,http_user_agent,request_uri ORDER by "PV" desc
查看NGINX监控中心
- 在仪表盘模板下方,选择“NGINX仪表盘模板 > NGINX监控中心”,查看图表详情。
- 访问量PV图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,PV FROM ( SELECT TIME_CEIL ( __time, 'PT300S' ) AS _time_, count( 1 ) AS PV FROM log GROUP BY _time_ ) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100 OFFSET 1
- 请求成功率图表所关联的查询分析语句如下所示:
select ROUND(sum(case when status < 400 then 1 else 0 end) * 100.0 / count(1),2) as cnt
- 平均延迟图表所关联的查询分析语句如下所示:
select round(avg(request_time) * 1000, 3) as cnt
- 4XX请求数图表所关联的查询分析语句如下所示:
SELECT COUNT(1) as cnt WHERE "status" >= 400 and "status" < 500
- 404请求数图表所关联的查询分析语句如下所示:
SELECT COUNT(1) as cnt WHERE "status" = 404
- 429请求数图表所关联的查询分析语句如下所示:
SELECT COUNT(1) as cnt WHERE "status" = 429
- 504请求数图表所关联的查询分析语句如下所示:
SELECT COUNT(1) as cnt WHERE "status" = 504
- 5XX请求数图表所关联的查询分析语句如下所示:
select TIME_FORMAT(TIME_CEIL(__time,'PT300S'),'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_ , count(1) as cnt where "status" >= 500 group by _time_
- 状态码分布图表所关联的查询分析语句如下所示:
SELECT status, COUNT(1) AS rm GROUP BY status
- 访问量UV图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,UV FROM (select TIME_CEIL(__time,'PT600S') AS _time_ , APPROX_COUNT_DISTINCT(remote_addr) as UV from log group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
select TIME_FORMAT(_time_,'yyyy-MM-dd HH:mm:ss','+08:00') AS _time_,round( CASE WHEN "入流量" > 0 THEN "入流量" ELSE 0 END, 2 ) AS "入流量",round( CASE WHEN "出流量" > 0 THEN "出流量" ELSE 0 END, 2 ) AS "出流量" FROM (SELECT TIME_CEIL(__time,'PT600S') AS _time_,sum(request_length) / 1024.0 AS "入流量",sum(bytes_sent) / 1024.0 AS "出流量" group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
- 访问失败率图表所关联的查询分析语句如下所示:
SELECT TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "失败率" > 0 THEN "失败率" ELSE 0 END, 2 ) AS "失败率",round( CASE WHEN "5XX比例" > 0 THEN "5XX比例" ELSE 0 END, 2 ) AS "5XX比例" from (select TIME_CEIL(__time,'PT600S') AS _time_,sum(case when status >= 400 then 1 else 0 end) * 100.0 / count(1) as '失败率' , sum(case when status >=500 THEN 1 ELSE 0 END)*100.0/COUNT(1) as '5XX比例' group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
select TIME_FORMAT( _time_, 'yyyy-MM-dd HH:mm:ss', '+08:00' ) as _time_,round( CASE WHEN "平均" > 0 THEN "平均" ELSE 0 END, 2 ) AS "平均",round( CASE WHEN "P50" > 0 THEN "P50" ELSE 0 END, 2 ) AS "P50",round( CASE WHEN "P90" > 0 THEN "P90" ELSE 0 END, 2 ) AS "P90",round( CASE WHEN "P99" > 0 THEN "P99" ELSE 0 END, 2 ) AS "P99",round( CASE WHEN "P9999" > 0 THEN "P9999" ELSE 0 END, 2 ) AS "P9999" from (select TIME_CEIL(__time,'PT600S') as _time_,avg(request_time) * 1000 as "平均", APPROX_QUANTILE_DS("request_time", 0.50)*1000 as "P50", APPROX_QUANTILE_DS("request_time", 0.90)*1000 as "P90" ,APPROX_QUANTILE_DS("request_time", 0.99)*1000 as 'P99',APPROX_QUANTILE_DS("request_time", 0.9999)*1000 as 'P9999' group by _time_) WHERE _time_ <= CURRENT_TIMESTAMP LIMIT 100000 OFFSET 1
- Host请求TOP图表所关联的查询分析语句如下所示:
SELECT "host", pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)" FROM ( SELECT "host", count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)" WHERE "host" != '' GROUP BY "host" ) ORDER BY pv DESC
- Host延迟TOP图表所关联的查询分析语句如下所示:
SELECT "host", pv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY "host" ) ORDER BY "平均延迟(ms)" desc
- Host失败率TOP图表所关联的查询分析语句如下所示:
SELECT "host", pv,round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM ( SELECT "host", count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY "host" ) ORDER BY "访问失败率(%)" desc
- URL请求TOP图表所关联的查询分析语句如下所示:
SELECT request_uri, pv,uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)" FROM ( SELECT request_uri, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)" WHERE "host" != '' GROUP BY request_uri ) ORDER BY pv desc
- URL延迟TOP图表所关联的查询分析语句如下所示:
SELECT request_uri, pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY request_uri ) ORDER BY "平均延迟(ms)" desc
- URL失败率TOP图表所关联的查询分析语句如下所示:
SELECT request_uri, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM( SELECT request_uri, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY request_uri )ORDER BY "访问失败率(%)" desc
- 后端请求TOP图表所关联的查询分析语句如下所示:
SELECT addr, pv, uv, round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "入流量(KB)" > 0 THEN "入流量(KB)" ELSE 0 END, 3 ) AS "入流量(KB)", round( CASE WHEN "出流量(KB)" > 0 THEN "出流量(KB)" ELSE 0 END, 3 ) AS "出流量(KB)" FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, APPROX_COUNT_DISTINCT ( remote_addr ) AS uv, sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", sum( request_length ) / 1024.0 AS "入流量(KB)", sum( bytes_sent ) / 1024.0 AS "出流量(KB)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "pv" desc
- 后端延迟TOP图表所关联的查询分析语句如下所示:
SELECT addr,pv,round( CASE WHEN "访问成功率(%)" > 0 THEN "访问成功率(%)" ELSE 0 END, 2 ) AS "访问成功率(%)",round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)",round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)",round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM (SELECT upstream_addr as addr,count( 1 ) AS pv,sum( CASE WHEN "status" < 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问成功率(%)",avg( request_time ) * 1000 AS "平均延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)",APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2) ORDER BY "平均延迟(ms)" desc
- 后端失败率TOP图表所关联的查询分析语句如下所示:
SELECT addr, pv, round( CASE WHEN "访问失败率(%)" > 0 THEN "访问失败率(%)" ELSE 0 END, 2 ) AS "访问失败率(%)", round( CASE WHEN "平均延迟(ms)" > 0 THEN "平均延迟(ms)" ELSE 0 END, 3 ) AS "平均延迟(ms)", round( CASE WHEN "P90延迟(ms)" > 0 THEN "P90延迟(ms)" ELSE 0 END, 3 ) AS "P90延迟(ms)", round( CASE WHEN "P99延迟(ms)" > 0 THEN "P99延迟(ms)" ELSE 0 END, 3 ) AS "P99延迟(ms)" FROM ( SELECT upstream_addr as addr, count( 1 ) AS pv, sum( CASE WHEN "status" >= 400 THEN 1 ELSE 0 END ) * 100.0 / count( 1 ) AS "访问失败率(%)", avg( request_time ) * 1000 AS "平均延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.9) * 1000 AS "P90延迟(ms)", APPROX_QUANTILE_DS(request_time, 0.99) * 1000 AS "P99延迟(ms)" WHERE "host" != '' GROUP BY addr having length(upstream_addr) > 2)ORDER BY "访问失败率(%)" desc
