Updated on 2025-05-12 GMT+08:00
Creating a Signed URL (SDK for Go)
Function
This API creates a URL whose Query parameters are carried with authentication information by specifying the AK and SK, HTTP method, and request parameters. You can provide other users with this URL for temporary access. When generating a URL, you need to specify the validity period of the URL to restrict the access duration of visitors.
If you want to grant other users the permission to perform other operations on buckets or objects (for example, upload or download objects), generate a URL with the corresponding request (for example, to upload an object using the URL that generates the PUT request) and provide the URL for other users.
Restrictions
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • If a CORS or signature mismatch error occurs, refer to the following steps to troubleshoot the issue:
    1. If CORS is not configured, you need to configure CORS rules on OBS Console. For details, see Configuring CORS.
    2. If the signatures do not match, check whether signature parameters are correct. For details, see Authentication of Signature in a URL. For example, during an object upload, the backend uses Content-Type to calculate the signature and generate an authorized URL, but if Content-Type is not set or is set to an incorrect value when the frontend uses the authorized URL, a CORS error occurs. To avoid this issue, ensure that Content-Type fields at both the frontend and backend are kept consistent.
Method
func (obsClient ObsClient) CreateSignedUrl(input *CreateSignedUrlInput) (output *CreateSignedUrlOutput, err error)
Request Parameters
Table 1 List of request parameters
Parameter
Type
Mandatory (Yes/No)
Description
input
Yes
Explanation:
Input parameters for creating a signed URL. For details, see Table 2.
Table 2 CreateSignedUrlInput
Parameter
Type
Mandatory (Yes/No)
Description
Method
HttpMethodType
Yes
Explanation:
HTTP method. For details, see Table 3.
Bucket
string
No
Explanation:
Bucket name
Restrictions:
  • A bucket name:
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Key
string
No
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
SubResource
SubResourceType
No
Explanation:
Type of the subresource to access. For details, see Table 4.
Expires
int
No
Explanation:
Expiration time of the signed URL
Value range:
  • The value of this parameter for temporary credentials ranges from 0 to 86400, in seconds.
  • The value of this parameter for permanent keys ranges from 0 to 630720000, in seconds.
Default value:
300
Headers
map[string]string
No
Explanation:
Headers in the request
Default value:
None
QueryParams
map[string]string
No
Explanation:
Query parameters in the request
Default value:
None
Table 3 HttpMethodType
Constant
Default Value
Description
HttpMethodGet
GET
HTTP GET request
HttpMethodPut
POST
HTTP POST request
HttpMethodPost
PUT
HTTP PUT request
HttpMethodDelete
DELETE
HTTP DELETE request
HttpMethodHead
HEAD
HTTP HEAD request
HttpMethodOptions
OPTIONS
HTTP OPTIONS request
Table 4 SubResourceType
Constant
Default Value
Applicable API
SubResourceStoragePolicy
storagePolicy
Sets or obtains bucket storage classes.
SubResourceQuota
quota
Sets or obtains bucket quotas.
SubResourceStorageInfo
storageinfo
Obtains bucket storage information.
SubResourceLocation
location
Obtains bucket locations.
SubResourceAcl
acl
Sets or obtains bucket ACLs or object ACLs.
SubResourcePolicy
policy
Sets, obtains, or deletes bucket policies.
SubResourceCors
cors
Sets, obtains, or deletes bucket CORS configurations.
SubResourceVersioning
versioning
Sets or obtains bucket version statuses.
SubResourceWebsite
website
Sets, obtains, or deletes bucket website configurations.
SubResourceLogging
logging
Sets or obtains bucket logging settings.
SubResourceLifecycle
lifecycle
Sets, obtains, or deletes lifecycle rules of buckets.
SubResourceNotification
notification
Sets or obtains the notification configuration of buckets.
SubResourceTagging
tagging
Sets, obtains, or deletes bucket tags.
SubResourceDelete
delete
Batch deletes objects.
SubResourceVersions
versions
Lists versioning objects in buckets.
SubResourceUploads
uploads
Lists or initializes multipart uploads in buckets.
SubResourceRestore
restore
Restores Archive objects.
Responses
Table 5 List of returned results
Parameter
Type
Description
output
Explanation:
Returned results. For details, see Table 6.
err
error
Explanation:
Error messages returned by the API
Table 6 CreateSignedUrlOutput
Parameter
Type
Description
SignedUrl
string
Explanation:
Signed URL
Default value:
None
ActualSignedRequestHeaders
http.Header
Explanation:
Actual headers in the request initiated by using the signed URL
Default value:
None
Code Example
This example creates a signed URL for uploading an object.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
package main
import (
    "fmt"
    "net/http"
    "os"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    putObjectInput := &obs.CreateSignedUrlInput{}
    putObjectInput.Method = obs.HttpMethodPut
    putObjectInput.Bucket = "examplebucket"
    putObjectInput.Key = "example/objectname"
    putObjectInput.Expires = 3600
    // Create a signed URL for uploading an object.
    putObjectOutput, err := obsClient.CreateSignedUrl(putObjectInput)
    if err != nil {
        fmt.Println(err)
        return
    fmt.Printf("SignedUrl:%s\n", putObjectOutput.SignedUrl)
    fmt.Printf("ActualSignedRequestHeaders:%v\n", putObjectOutput.ActualSignedRequestHeaders)
    // Call the signed URL.
    payload := strings.NewReader("hello OBS!")
    req, err := http.NewRequest("PUT", putObjectOutput.SignedUrl, payload)
    req.Header = putObjectOutput.ActualSignedRequestHeaders
    if err != nil {
        fmt.Printf("Create request error, errMsg: %s", err.Error())
        return
    response, err := http.DefaultClient.Do(req)
    if err == nil {
        fmt.Printf("Use signed-url successful!\n")
        fmt.Printf("Status:%s,Etag:%s\n", response.Status, response.Header.Get("Etag"))
        return
    fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
    fmt.Println(err)
This example creates a signed URL for downloading an object.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
package main
import (
    "fmt"
    "net/http"
    "os"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    if err != nil {
    getObjectInput := &obs.CreateSignedUrlInput{}
    getObjectInput.Method = obs.HttpMethodGet
    getObjectInput.Bucket = "examplebucket"
    getObjectInput.Key = "example/objectname"
    getObjectInput.Expires = 3600
    // Create a signed URL for downloading an object.
    getObjectOutput, err := obsClient.CreateSignedUrl(getObjectInput)
    if err != nil {
        fmt.Println(err)
        return
    fmt.Printf("SignedUrl:%s\n", getObjectOutput.SignedUrl)
    fmt.Printf("ActualSignedRequestHeaders:%v\n", getObjectOutput.ActualSignedRequestHeaders)
    req, err := http.NewRequest("GET", getObjectOutput.SignedUrl, nil)
    req.Header = getObjectOutput.ActualSignedRequestHeaders
    if err != nil {
        return
    if err == nil {
        p := make([]byte, 1024)
        var readErr error
        var readCount int
        // Read the object content.
        for {
            readCount, readErr = response.Body.Read(p)
            if readCount > 0 {
                fmt.Printf("%s", p[:readCount])
            if readErr != nil {
                break
        return
    fmt.Println(err)
This example creates a signed URL for deleting an object.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
package main
import (
    "fmt"
    "net/http"
    "os"
func main() {
    if err != nil {
    // Create a signed URL for deleting an object.
    deleteObjectInput := &obs.CreateSignedUrlInput{}
    deleteObjectInput.Method = obs.HttpMethodDelete
    deleteObjectInput.Bucket = "examplebucket"
    deleteObjectInput.Key = "example/objectname"
    deleteObjectInput.Expires = 3600
    deleteObjectOutput, err := obsClient.CreateSignedUrl(deleteObjectInput)
    if err != nil {
        fmt.Println(err)
        return
    fmt.Printf("SignedUrl:%s\n", deleteObjectOutput.SignedUrl)
    fmt.Printf("ActualSignedRequestHeaders:%v\n", deleteObjectOutput.ActualSignedRequestHeaders)
    req, err := http.NewRequest("DELETE", deleteObjectOutput.SignedUrl, nil)
    req.Header = deleteObjectOutput.ActualSignedRequestHeaders
    if err != nil {
        return
    if err == nil {
        fmt.Printf("Status:%s\n", response.Status)
        return
    fmt.Println(err)
