Creating Authentication Parameters for a Browser-based Upload (SDK for Go)
Function
This API generates parameters for authentication. The parameters can be used to upload data through POST operations based on a browser.
There are two request parameters generated:
- Policy, which corresponds to the policy parameter in the form
- Signature, which corresponds to the x-obs-signature parameter in the form
Restrictions
- To upload an object, you must be the bucket owner or have the required permission (obs:object:PutObject in IAM or PutObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
func (obsClient ObsClient) CreateBrowserBasedSignature(input *CreateBrowserBasedSignatureInput) (output *CreateBrowserBasedSignatureOutput, err error)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
input |
Yes |
Explanation: Input parameters for creating authentication parameters for a browser-based upload. For details, see Table 2. |
Parameter |
Type |
Description |
Bucket |
string |
No |
Explanation: Bucket name Restrictions:
Default value: None |
Key |
string |
No |
Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
Expires |
int |
No |
Explanation: Expiration time of authentication for a browser-based upload Value range: 0 to (263 – 1), in seconds Default value: 300 |
FormParams |
map[string]string |
No |
Explanation: Parameters of a browser-based upload, not including key, policy, and signature. Value range: acl, cache-control, content-type, content-disposition, content-encoding, and expires Default value: None |
Responses
Parameter |
Type |
Description |
output |
Explanation: Returned results. For details, see Table 4. |
err |
error |
Explanation: Error messages returned by the API |
Parameter |
Type |
Description |
OriginPolicy |
string |
Explanation: policy not encoded by Base64. This parameter can only be used for verification. Example: {"expiration":"2023-09-12T12:52:59Z","conditions":[{"content-type":"text/plain"},{"bucket":"examplebucket"},{"key":"example/objectname"},]}" Default value: None |
Policy |
string |
Explanation: Base64-encoded value of policy in the form Example: eyJleHBpcmF0aW9uIjoiMjAyMy0wOS0xMlQxMjo1Mjo1OVoiLCJjb25kaXRpb25zIjpbeyJjb250ZW50LXR5cGUiOiJ0ZXh0L3BsYWluIn0seyJidWNrZXQiOiJleGFtcGxlYnVja2V0In0seyJrZXkiOiJleGFtcGxlL29iamVjdG5hbWUifSxdfQ== Default value: None |
Signature |
string |
Explanation: signature in the form Example: g0jQr4v9VWd1Q2FOFDG6LGfV9Cw= Default value: None |
Code Example
This example creates a signed URL for uploading an object using POST.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 |
package main import ( "fmt" "os" obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs" ) func main() { //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage. //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak := os.Getenv("AccessKeyID") sk := os.Getenv("SecretAccessKey") // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. // securityToken := os.Getenv("SecurityToken") // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com" // Create an obsClient instance. // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance. obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/) if err != nil { fmt.Printf("Create obsClient error, errMsg: %s", err.Error()) } // Create a signed URL for uploading an object. input := &obs.CreateBrowserBasedSignatureInput{} input.Bucket = "examplebucket" input.Key = "example/objectname" input.FormParams = map[string]string{ "content-type": "text/plain", "success_action_redirect": "https://www.example.com", "x-obs-acl": "public-read", } output, err := obsClient.CreateBrowserBasedSignature(input) if err == nil { fmt.Printf("Policy:%s\n", output.Policy) fmt.Printf("Signature:%s\n", output.Signature) } else { fmt.Println(err) return } requestBody := &bytes.Buffer{} writer := multipart.NewWriter(requestBody) writer.WriteField("key", input.Key) writer.WriteField("AccessKeyId", ak) writer.WriteField("policy", output.Policy) writer.WriteField("signature", output.Signature) writer.WriteField("success_action_redirect", "https://www.example.com") // writer.WriteField("token", obs.WithSecurityToken(securityToken)) writer.WriteField("Content-Type", "text/plain") formFile, _ := writer.CreateFormFile("file", "filename") io.Copy(formFile, strings.NewReader("hello OBS!")) writer.Close() url := "https://" + input.Bucket + "." + strings.Replace(endPoint, "https://", "", 1) request, err := http.NewRequest("POST", url, requestBody) if err != nil { fmt.Println(err) return } request.Header.Set("Content-Type", writer.FormDataContentType()) client := &http.Client{} response, err := client.Do(request) if err != nil { fmt.Println(err) return } defer response.Body.Close() if err == nil { fmt.Printf("Use signed-url successful!\n") fmt.Printf("Status:%s,Etag:%s\n", response.Status, response.Header.Get("Etag")) return } fmt.Printf("Use signed-url successful!\n") fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.") fmt.Println(err) } |
Feedback
Was this page helpful?
Chatbot
