Configuring Lifecycle Rules for a Bucket (SDK for Python)
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API configures lifecycle rules for a bucket.
- Expired objects will be permanently deleted and cannot be recovered.
- Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
- The minimum storage duration is 30 days for Infrequent Access storage, and 90 days for Archive storage. After an object is transitioned to the Archive storage class, if it stays in this storage class for less than 90 days, you still need to pay for a full 90 days.
Restrictions
- There is no limit on the number of lifecycle rules in a bucket, but the total size of XML descriptions about all lifecycle rules in a bucket cannot exceed 20 KB.
- A maximum of 20 lifecycle rules can be configured for a parallel file system.
- To configure a lifecycle rule for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutLifecycleConfiguration in IAM or PutLifecycleConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketLifecycle(bucketName, lifecycle, extensionHeaders)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
str |
Yes |
Explanation: Bucket name Restrictions:
Default value: None |
lifecycle |
Yes |
Explanation: List of lifecycle rules. For details, see Table 1. Default value: None |
extensionHeaders |
dict |
No |
Explanation: Extension headers. Value range: See User-defined Header (SDK for Python). Default value: None |
Parameter |
Type |
Description |
rule |
list of Rule |
Yes |
Explanation: List of lifecycle rules. For details, see Table 2. Default value: None |
Parameter |
Type |
Description |
id |
str |
No |
Explanation: Lifecycle rule ID Value range: The value must contain 1 to 255 characters. Default value: None |
prefix |
str |
Yes |
Explanation: Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket. Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set Prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg only. If you set Prefix to logs/, the rule applies to the three objects with name starting with logs/. If you leave Prefix blank, the rule applies to all objects in the bucket. Value range: The value must contain 1 to 1,024 characters. Default value: None |
status |
str |
Yes |
Explanation: Whether the rule is enabled Value range:
transition |
or list of Transition |
No |
Explanation: Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 3. Restrictions: This parameter applies only to the current object version. Default value: None |
expiration |
No |
Explanation: Object expiration time. For details, see Table 4. Restrictions: This parameter applies only to the current object version. Default value: None |
noncurrentVersionTransition |
or list of NoncurrentVersionTransition |
No |
Explanation: Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 7. Restrictions:
noncurrentVersionExpiration |
No |
Explanation: Expiration time of noncurrent object versions. For details, see Table 8. Restrictions:
CAUTION:
This parameter is not available for parallel file systems. Default value: None |
Parameter |
Type |
Description |
storageClass |
str |
Yes if used as a request parameter |
Explanation: Storage class of the object after transition Restrictions:
Value range: See Table 5. Default value: None |
date |
str or |
Yes if the parameter is used as a request parameter and days is absent |
Explanation: OBS executes the lifecycle rule for objects that were modified before the specified date. Restrictions: The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are transitioned to the specified storage class. For example, DateTime(year=2023, month=9, day=12) Default value: None |
days |
int |
Yes if the parameter is used as a request parameter and date is absent |
Explanation: Number of days (since the last update was made to the object) after which the lifecycle rule takes effect Restrictions: This parameter applies only to the current object version. Value range: An integer greater than or equal to 0, in days Default value: None |
Parameter |
Type |
Description |
date |
str or |
Explanation: OBS executes the lifecycle rule for objects that were modified before the specified date. Restrictions: The value must conform with the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are deleted. For example, DateTime(year=2023, month=9, day=12) Default value: None |
days |
int |
Parameter |
Type |
Description |
STANDARD |
Standard storage class |
Explanation: Features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
WARM |
Infrequent Access storage class |
Explanation: Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but is instantly available when needed. |
COLD |
Archive storage class |
Explanation: Used for storing rarely accessed (once a year) data. |
Parameter |
Type |
Description |
year |
int |
Explanation: Year in UTC Default value: None |
month |
int |
Explanation: Month in UTC Default value: None |
day |
int |
Explanation: Day in UTC Default value: None |
hour |
int |
Explanation: Hour in UTC Restrictions: The value is in 24-hour format. Default value: 0 |
min |
int |
Explanation: Minute in UTC Default value: 0 |
sec |
int |
Explanation: Second in UTC Default value: 0 |
Parameter |
Type |
Description |
storageClass |
str |
Explanation: Storage class of noncurrent object versions after transition Restrictions:
noncurrentDays |
int |
Explanation: Number of days an object is noncurrent before the specified rule takes effect Restrictions: This parameter applies only to noncurrent object versions. Value range: An integer greater than or equal to 0, in days Default value: None |
Parameter |
Type |
Description |
noncurrentDays |
int |
Responses
Type |
Description |
Explanation: SDK common results |
Parameter |
Type |
Description |
status |
int |
Explanation: HTTP status code Value range: A status code is a group of digits ranging from 2xx (indicating successes) to 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
reason |
str |
Explanation: Reason description. Default value: None |
errorCode |
str |
Explanation: Error code returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
errorMessage |
str |
Explanation: Error message returned by the OBS server. If the value of status is less than 300, this parameter is left blank. Default value: None |
requestId |
str |
Explanation: Request ID returned by the OBS server Default value: None |
indicator |
str |
Explanation: Error indicator returned by the OBS server. Default value: None |
hostId |
str |
Explanation: Requested server ID. If the value of status is less than 300, this parameter is left blank. Default value: None |
resource |
str |
Explanation: Error source (a bucket or an object). If the value of status is less than 300, this parameter is left blank. Default value: None |
header |
list |
Explanation: Response header list, composed of tuples. Each tuple consists of two elements, respectively corresponding to the key and value of a response header. Default value: None |
body |
object |
Explanation: Result content returned after the operation is successful. If the value of status is larger than 300, the value of body is null. The value varies with the API being called. For details, see Bucket-Related APIs (SDK for Python) and Object-Related APIs (SDK for Python). Default value: None |
Code Examples
This example configures a lifecycle rule for bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 |
from obs import ObsClient from obs import Expiration, NoncurrentVersionExpiration from obs import DateTime from obs import Rule from obs import Lifecycle import os import traceback # Obtain an AK and SK pair using environment variables or import the AK and SK pair in other ways. Using hard coding may result in leakage. # Obtain an AK and SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html. ak = os.getenv("AccessKeyID") sk = os.getenv("SecretAccessKey") # (Optional) If you use a temporary AK and SK pair and a security token to access OBS, obtain them from environment variables. # security_token = os.getenv("SecurityToken") # Set server to the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in use. server = "https://obs.ap-southeast-1.myhuaweicloud.com" # Create an obsClient instance. # If you use a temporary AK and SK pair and a security token to access OBS, you must specify security_token when creating an instance. obsClient = ObsClient(access_key_id=ak, secret_access_key=sk, server=server) try: # Configure a lifecycle rule for deleting objects with prefix1 as the prefix after 60 days since the last update. rule1 = Rule(id='rule1', prefix='prefix1', status='Enabled', expiration=Expiration(days=60)) # Configure a lifecycle rule for deleting objects with prefix2 as the prefix on December 31, 2023. rule2 = Rule(id='rule2', prefix='prefix2', status='Enabled', expiration=Expiration(date=DateTime(2023, 12, 31))) lifecycle = Lifecycle(rule=[rule1, rule2]) bucketName="examplebucket" # Configures the lifecycle rules for the bucket. resp = obsClient.setBucketLifecycle(bucketName, lifecycle) # If status code 2xx is returned, the API is called successfully. Otherwise, the API call fails. if resp.status < 300: print('Set Bucket Lifecycle Succeeded') print('requestId:', resp.requestId) else: print('Set Bucket Lifecycle Failed') print('requestId:', resp.requestId) print('errorCode:', resp.errorCode) print('errorMessage:', resp.errorMessage) except: print('Set Bucket Lifecycle Failed') print(traceback.format_exc()) |
Feedback
Was this page helpful?
Chatbot
