percentile
This function is used to return the exact percentile, which is applicable to a small amount of data. It sorts a specified column in ascending order, and then obtains the exact value of the pth percentile.
Syntax
percentile(colname,DOUBLE p)
Parameters
Parameter |
Mandatory |
Type |
Description |
colname |
Yes |
STRING |
Name of the column to be sorted The elements in the column must be integers. |
p |
Yes |
DOUBLE |
The value ranges from 0 to 1. The value is a float. |
Return Values
The return value is of the DOUBLE or ARRAY type.
- If the column name does not exist, an error is reported.
- If the value of p is NULL or outside the range of [0, 1], an error is reported.
Example Code
Assume that the elements in the int_test column are 1, 2, 3, and 4 and they are of the INT type.
The value 3.0999999999999996 is returned.
select percentile(int_test,0.7) FROM int_test;
The value 3.997 is returned.
select percentile(int_test,0.999) FROM int_test;
The value 2.5 is returned.
select percentile(int_test,0.5) FROM int_test;
The value [1.3, 1.9, 2.5, 2.8, 3.7] is returned.
select percentile (int_test,ARRAY(0.1,0.3,0.5,0.6,0.9)) FROM int_test;
Feedback
Was this page helpful?
Chatbot
