Updated on 2024-12-09 GMT+08:00
Server-Side Encryption (SDK for Go)
Function
This API configures server-side encryption for objects, so that they will be encrypted or decrypted when you upload them to or download them from a bucket.
The encryption and decryption happen on the server side.
There are different encryption methods for you to choose from. Available encryption methods include server-side encryption with KMS-managed keys (SSE-KMS) and server-side encryption with customer-provided keys (SSE-C). Both of the two methods use the AES-256 algorithm.
With SSE-KMS, OBS uses the keys provided by KMS for server-side encryption.
With SSE-C, OBS uses the keys and MD5 values provided by customers for server-side encryption.
When server-side encryption is used, the returned ETag value is not the object's MD5 value. OBS will verify the object's MD5 value as long as the upload request includes the Content-MD5 header, no matter whether server-side encryption is used or not.
For more information, see Server-Side Encryption.
Restrictions
Method
func (obsClient ObsClient) PutFile(input *PutFileInput) (output *PutObjectOutput, err error)
Supported APIs
The following table lists APIs related to server-side encryption:
Method in OBS SDK for Go
Description
Supported Encryption Method
ObsClient.PutObject
Sets the encryption algorithm and key during object upload to enable server-side encryption.
SSE-KMS
SSE-C
ObsClient.PutFile
Sets the encryption algorithm and key during file upload to enable server-side encryption.
SSE-KMS
SSE-C
ObsClient.GetObject
Sets the decryption algorithm and key during object download to decrypt the object.
SSE-C
ObsClient.CopyObject
  1. Sets the decryption algorithm and key for decrypting the source object during object copy.
  2. Sets the encryption algorithm and key during object copy to enable the encryption algorithm for the target object.
SSE-KMS
SSE-C
ObsClient.GetObjectMetadata
Sets the decryption algorithm and key when obtaining the object metadata to decrypt the object.
SSE-C
ObsClient.InitiateMultipartUpload
Sets the encryption algorithm and key when initializing a multipart upload task to enable server-side encryption for the final object generated.
SSE-KMS
SSE-C
ObsClient.UploadPart
Sets the encryption algorithm and key during multipart upload to enable server-side encryption for parts.
SSE-C
ObsClient.CopyPart
  1. Sets the decryption algorithm and key for decrypting the source object during multipart copy.
  2. Sets the encryption algorithm and key during multipart copy to enable the encryption algorithm for the target part.
SSE-C
Code Examples
This example encrypts object example/objectname that is uploaded using streaming.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
package main
import (
    "crypto/md5"
    "encoding/base64"
    "fmt"
    "os"
    "strings"
    obs "github.com/huaweicloud/huaweicloud-sdk-go-obs/obs"
func main() {
    //Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    //Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    ak := os.Getenv("AccessKeyID")
    sk := os.Getenv("SecretAccessKey")
    // (Optional) If you use a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding to reduce leakage risks. You can obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways.
    // securityToken := os.Getenv("SecurityToken")
    // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    endPoint := "https://obs.ap-southeast-1.myhuaweicloud.com"
    // Create an obsClient instance.
    // If you use a temporary AK/SK pair and a security token to access OBS, use the obs.WithSecurityToken method to specify a security token when creating an instance.
    obsClient, err := obs.New(ak, sk, endPoint/*, obs.WithSecurityToken(securityToken)*/)
    if err != nil {
        fmt.Printf("Create obsClient error, errMsg: %s", err.Error())
    input := &obs.PutObjectInput{}
    // Specify a bucket name.
    input.Bucket = "examplebucket"
    // Specify the object (example/objectname as an example) to upload.
    input.Key = "example/objectname"
    // Specify the content to upload.
    input.Body = strings.NewReader("Hello OBS")
    // Specify a server-side encryption header (obs.SseCHeader as an example).
    key := os.Getenv("Key")
    digest := md5.New()
    digest.Write([]byte(key))
    bodyHash := digest.Sum(nil)
    input.SseHeader = obs.SseCHeader{
        Encryption: "AES256",
        Key:        base64.StdEncoding.EncodeToString([]byte(key)), // 32byteslongsecretkeymustprovided
        KeyMD5:     base64.StdEncoding.EncodeToString(bodyHash),
    // Upload you local file using streaming.
    output, err := obsClient.PutObject(input)
    if err == nil {
        fmt.Printf("Put object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("RequestId:%s\n", output.RequestId)
        fmt.Printf("StorageClass:%s, ETag:%s\n",
            output.StorageClass, output.ETag)
        return
    fmt.Printf("Put object(%s) under the bucket(%s) fail!\n", input.Key, input.Bucket)
    if obsError, ok := err.(obs.ObsError); ok {
        fmt.Println("An ObsError was found, which means your request sent to OBS was rejected with an error response.")
        fmt.Println(obsError.Error())
        fmt.Println("An Exception was found, which means the client encountered an internal problem when attempting to communicate with OBS, for example, the client was unable to access the network.")
        fmt.Println(err)
This example downloads the encrypted object example/objectname using streaming.
 1
 2
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
package main
import (
    "crypto/md5"
    "encoding/base64"
    "fmt"
    "os"
func main() {
    // Obtain an AK/SK pair using environment variables or import an AK/SK pair in other ways. Using hard coding may result in leakage.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.cn/intl/en-us/usermanual-ca/ca_01_0003.html.
    if err != nil {
    input := &obs.GetObjectInput{}
    // Specify the object (example/objectname as an example) to download.
    digest := md5.New()
    // Download the object using streaming.
    output, err := obsClient.GetObject(input)
    if err == nil {
        // Close output.Body after using it, to avoid connection leakage.
        defer output.Body.Close()
        fmt.Printf("Get object(%s) under the bucket(%s) successful!\n", input.Key, input.Bucket)
        fmt.Printf("StorageClass:%s, ETag:%s, ContentType:%s, ContentLength:%d, LastModified:%s\n",
            output.StorageClass, output.ETag, output.ContentType, output.ContentLength, output.LastModified)
        // Read the object content.
        p := make([]byte, 1024)
        var readErr error
        var readCount int
        for {
            readCount, readErr = output.Body.Read(p)
            if readCount > 0 {
                fmt.Printf("%s", p[:readCount])
            if readErr != nil {
                break
        return
    fmt.Printf("List objects under the bucket(%s) fail!\n", input.Bucket)
        fmt.Println(err)
