Updated on 2025-04-02 GMT+08:00
Overview
Table 1 lists the date functions supported by DLI.
Table 1 Date/time functions
Function
Syntax
Value Type
Description
add_months
add_months(string start_date, int num_months)
STRING
Returns the date that is num_months after start_date.
current_date
current_date()
DATE
Returns the current date, for example, 2016-07-04.
current_timestamp
current_timestamp()
TIMESTAMP
Returns a timestamp of the TIMESTAMP type.
date_add
date_add(string startdate, int days)
STRING or DATE
Adds a number of days to a date.
dateadd
dateadd(string date, bigint delta, string datepart)
STRING or DATE
Changes a date based on datepart and delta.
date: This parameter is mandatory. Date value, which is of the STRING type.
The time format is yyyy-mm-dd hh:mi:ss, for example, 2021-08-28 00:00:00.
delta: This parameter is mandatory. Adjustment amplitude, which is of the BIGINT type.
datepart: Adjustment unit, which is a constant of the STRING type. This parameter is mandatory.
date_sub
date_sub(string startdate, int days)
STRING
Subtracts a number of days from a date.
date_format
date_format(string date, string format)
STRING
Converts a date into a string based on the format specified by format.
datediff
datediff(string date1, string date2)
BIGINT
Calculates the difference between date1 and date2.
datediff1
datediff1(string date1, string date2, string datepart)
BIGINT
Calculates the difference between date1 and date2 and returns the difference in a specified datepart.
datepart
datepart (string date, string datepart)
BIGINT
Returns the value of the field that meets a specified time unit in the date.
datetrunc
datetrunc (string date, string datepart)
STRING
Calculates the date otained through the truncation of a specified date based on a specified datepart.
date: The value is in the yyyy-mm-dd or yyyy-mm-dd hh:mi:ss format. This parameter is mandatory.
datepart: Supported date format, which is a STRING constant. This parameter is mandatory.
day/dayofmonth
day(string date), dayofmonth(string date)
INT
Returns the date of a specified time.
from_unixtime
from_unixtime(bigint unixtime)
STRING
Converts a timestamp to a time, in yyyy-MM-dd HH:mm:ss or yyyyMMddHHmmss.uuuuuu format.
For example, select FROM_UNIXTIME(1608135036,'yyyy-MM-dd HH:mm:ss').
from_utc_timestamp
from_utc_timestamp(string timestamp, string timezone)
TIMESTAMP
Converts a UTC timestamp to the corresponding timestamp in a specific time zone.
getdate
getdate()
STRING
Obtains the current system time.
hour
hour(string date)
INT
Returns the hour (from 0 to 23) of a specified time.
isdate
isdate(string date , string format)
BOOLEAN
date: Date, which is implicitly converted to the STRING type and then used for calculation. This parameter is mandatory.
format: Unsupported date extension format, which is a STRING constant. This parameter is mandatory. If there are redundant format strings in format, only the date value corresponding to the first format string is used. Other format strings are used as separators. For example, isdate("1234-yyyy", "yyyy-yyyy") returns True.
last_day
last_day(string date)
DATE
Returns the last day of the month a date belongs to, in the format of yyyy-MM-dd, for example, 2015-08-31.
lastday
lastday(string date)
STRING
Returns the last day of the month a date belongs to. The value is of the STRING type and is in the yyyy-mm-dd hh:mi:ss format.
minute
minute(string date)
INT
Returns the minute (from 0 to 59) of a specified time.
month
month(string date)
INT
Returns the month (from January to December) of a specified time.
months_between
months_between(string date1, string date2)
DOUBLE
Returns the month difference between date1 and date2.
next_day
next_day(string start_date, string day_of_week)
DATE
Returns the date closest to day_of_week after start_date, in the yyyy-MM-dd format. day_of_week indicates a day in a week, for example, Monday or Friday.
quarter
quarter(string date)
INT
Returns the quarter of the date, timestamp, or string, for example, quarter('2015-04-01')=2.
second
second(string date)
INT
Returns the second (from 0 to 59) of a specified time.
to_char
to_char(string date, string format)
STRING
Converts a date into a string in a specified format.
to_date
to_date(string timestamp)
DATE
Returns the date part of a time string, for example, to_date("1970-01-01 00:00:00") = "1970-01-01".
to_date1
to_date1(string date, string format)
STRING
The value is of the STRING type, in the yyyy-mm-dd hh:mi:ss format. If the value of date or format is NULL, NULL is returned.
Converts a string in a specified format to a date value.
to_utc_timestamp
to_utc_timestamp(string timestamp, string timezone)
TIMESTAMP
Converts a timestamp in a given time zone to a UTC timestamp.
trunc
trunc(string date, string format)
DTAE
Resets the date in a specified format. Supported formats are MONTH/MON/MM and YEAR/YYYY/YY, for example, trunc('2015-03-17', 'MM') = 2015-03-01.
unix_timestamp
unix_timestamp(string timestamp, string pattern)
BIGINT
Returns a Unix timestamp (the number of seconds since 1970-01-01 00:00:00) as an unsigned integer if the function is called without parameters.
weekday
weekday (string date)
INT
Returns the day of the current week.
weekofyear
weekofyear(string date)
INT
Returns the week number (from 0 to 53) of a specified date.
year
year(string date)
INT
Returns the year of a specified date.
