Help Center/ Cloud Operations Center/ User Guide/ Application Management/ Automatically Associating Resources with an Application
Updated on 2025-09-11 GMT+08:00
Scenarios
You can associate resource instances with the same tag in an enterprise project with the same resource group for management.
Precautions
  • Automatic association is supported for an application only when resources are automatically associated with the corresponding group. For details about how to change the resource association method, see Modifying a Group.
  • The Automatic Resource Association button takes effect only after you click the corresponding group.
  • After automatic resource association is triggered, wait for the association task to be executed. The association duration depends on the total number of resources to be associated.
Automatically Associating an Application with Resources
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, expand the application, select the group to be associated with resources, and click Automatic Resource Association.
    Figure 1 Automatically associating resources with an application
    Automatic resource association rules can be modified. After the modification, other resources that meet the rules can be automatically associated. For details about modifying an automatic resource association rule, see Modifying a Group.
