Updated on 2025-09-11 GMT+08:00
Transferring Resources
Scenarios
After a group is associated with resources, you can move the resources in the group to another group.
Precautions
Resources can be transferred to application groups only when they belong to the same enterprise project as the application.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Applications in the upper left corner.
  4. In the application list on the left, expand the application, select a group, select the resources to be transferred, and click Transfer.
    Figure 1 Transferring resources
  5. Select the group to which this resource is to be transferred and click OK.
