Updated on 2025-09-08 GMT+08:00
Viewing Failed Tasks
Scenarios
You can view the details of failed task (if any) in the Failures area, including the task names and statuses. This section describes how to view failures.
Failure Types
Table 1 lists the types of failures that can be recorded in the Failures area.
Table 1 Failure types
Failure Type
Description
Creation failures
A task failed. For a failed task, the system rolls back the task and displays an error code, for example, Ecs.0013 Insufficient EIP quota.
Operation failures
  • Modifying ECS specifications
    If an ECS specifications modification failed, this operation is recorded in Failures.
Procedure
  1. Log in to the management console.
  2. Click in the upper left corner and select a region and project.
  3. Click . Under Compute, click Elastic Cloud Server.
  4. View Failures on the right side of common operations.
    Figure 1 Failures
  5. Click the number displayed in the Failures area to view task details.
    • Creation Failures: show the failed ECS creation tasks.
    • Operation Failures: show the tasks with failed operations and error codes, which help you troubleshoot the faults.
