Updated on 2025-09-15 GMT+08:00
Configuring a Precise Protection Rule
EdgeSec allows you to customize protection rules by combining HTTP headers, cookies, URLs, request parameters, and client IP addresses.
You can combine common HTTP fields, such as IP, Path, Referer, User Agent, and Params in a protection rule to let EdgeSec block, allow, only log, or initiate JS challenges on the requests that match the combined conditions.
A reference table can be added to a precise protection rule. The reference table takes effect for all protected domain names.
Prerequisites
A protected website has been added. For details, see Adding a Website to EdgeSec.
Constraints
  • It takes several minutes for a new rule to take effect. After the rule takes effect, protection events triggered by the rule will be displayed on the Events page.
  • If you configure Protective Action to Block for a precise protection rule, you can configure a known attack source rule by referring to Configuring a Known Attack Source Rule. EdgeSec will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
Application Scenarios
Precise protection rules are used for anti-leeching and website management background protection.
Procedure
  1. Log in to the EdgeSec console.
  2. In the navigation pane on the left, choose Edge Security > Website Settings. The Website Settings page is displayed.
  3. In the Policy column of the row containing the domain name, click the number to go to the Policies page.
    Figure 1 Website list
  4. In the Precise Protection configuration area, change Status as needed.
    Figure 2 Precise Protection configuration area
  5. Click Add Rule.
  6. In the displayed dialog box, add a rule by referring to Table 1 and Table 2.
    The settings shown in Figure 3 are used as an example. If a visitor tries to access a URL containing /admin, EdgeSec will block the request.
    To ensure that EdgeSec blocks only attack requests, configure Protective Action to Log only first and check whether normal requests are blocked on the Events page. If no normal requests are blocked, configure Protective Action to Block.
    Figure 3 Add Precise Protection Rule
    Table 1 Rule parameters
    Parameter
    Description
    Example Value
    Rule Name
    Name of a user-defined precise protection rule.
    Rule Description
    (Optional) Enter a description of rules.
    Condition List
    Click Add to add conditions. At least one condition needs to be added. You can add up to 30 conditions to a protection rule. If more than one condition is added, all of the conditions must be met for the rule to be applied. A condition includes the following parameters:
    Parameters for configuring a condition are described as follows:
    • Field
      NOTE:
      If Field is set to Geographical location or ASN, IPv6 address requests cannot be matched.
    • Subfield: Configure this field only when IP, Params, Cookie, or Header is selected for Field.
      NOTICE:
      The length of a subfield cannot exceed 2,048 bytes. Only digits, letters, underscores (_), and hyphens (-) are allowed.
    • Logic: Select a logical relationship from the drop-down list.
      NOTE:
      • If Include any value, Exclude any value, Equal to any value, Not equal to any value, Prefix is any value, Prefix is not any of them, Suffix is any value, or Suffix is not any of them is selected, select an existing reference table in the Content drop-down list. For details, see Creating a Reference Table to Configure Protection Metrics In Batches.
      • Exclude any value, Not equal to any value, Prefix is not any of them, and Suffix is not any of them indicates, respectively, that EdgeSec performs the protection action (block or log only) when the field in the access request does not contain, is not equal to, or the prefix or suffix is not any value set in the reference table. For example, assume that Path field is set to Exclude any value and the test reference table is selected. If test1, test2, and test3 are set in the test reference table, EdgeSec performs the protection action when the path of the access request does not contain test1, test2, or test3.
      • If the condition is length-related logic, the length value cannot be too large. Large requests can be intercepted before reaching the backend engine, preventing them from being processed and making protection rules ineffective.
    • Content: Enter or select the content of condition matching.
    NOTE:
    For more details about the configurations in general, see Table 2.
    • Path Include /admin
    • User Agent Prefix is not mozilla/5.0
    • IP Equal to 192.168.2.3
    • Cookie key1 Prefix is not jsessionid
    Protective Action
    You can select Block, Allow, Log only, or JS Challenge (EdgeSec returns JavaScript code).
    NOTE:
    • JS challenge cannot be performed across domains.
    • The functionality of the JavaScript challenge relies on the execution of JavaScript within a browser environment. Consequently, if the environment lacks full browser capabilities, such as text-only terminals or devices with incomplete browser support, the JavaScript challenge cannot be executed. This limitation arises because these environments are unable to run the JavaScript code essential for verifying user identity and validity, thus preventing the completion of the challenge process.
    • Upon successful completion of the JavaScript challenge, the response page requires rendering within a browser to ensure proper state restoration. Failure to render the response page in a browser context can lead to display issues, such as the persistent display of the challenge page.
    Block
    Known Attack Source
    If you set Protective Action to Block, you can select a blocking type for a known attack source rule. EdgeSec will block requests matching the configured IP address, Cookie, or Params for a length of time configured as part of the rule.
    Long-term IP address blocking
    Priority
    Rule priority. If you have added multiple rules, rules are matched by priority. The smaller the value you set, the higher the priority.
    You can use the priority function to rank all precise protection rules to get the optimal protection.
    • Set Priority: Set the priority value, which ranges from 1 to 100.
    • Designated Priority Position: Insert a new rule either before or after an existing rule. Upon insertion, the priority of the newly added rule is set, and the priorities of other rules are automatically adjusted.
    NOTICE:
    If multiple precise access control rules have the same priority, EdgeSec matches the rules in the sequence of time the rules are added.
    5
    Set Effective Time
    • Immediate: The rule takes effect immediately.
    • Time Segment: The rule takes effect in a specified period.
    • Periodically: The rule takes effect in the specified period of each day.
    Immediate
    Specific Period
    This parameter is mandatory when Set Effective Time is set to Periodically.
    Periodic Time Range
    Time Zone
    GMT+08:00
    Table 2 Condition list configurations
    Field
    Subfield
    Logic
    Example Content
    Path: Part of a URL that does not include a domain name. This value supports exact matches only. For example, if the path to be protected is /admin, Path must be set to /admin.
    None
    /buy/phone/
    NOTICE:
    If Path is set to /, all paths of the website are protected.
    User Agent: A user agent of the scanner to be checked.
    None
    Mozilla/5.0 (Windows NT 6.1)
    IP: Select the IP address of the visitor to be protected, which can be an IPv4 or IPv6 address.
    • Client IP Address
    • X-Forwarded-For
    XXX.XXX.1.1
    Params: A request parameter.
    None
    201901150929
    Cookie: A small piece of data to identify web visitors
    • All fields
    • Any subfield
    • Custom
    jsessionid
    Referer: A user-defined request resource.
    For example, if the protected path is /admin/xxx and you do not want visitors to access the page from www.test.com, set Content to http://www.test.com.
    None
    http://www.test.com
    Header: A user-defined HTTP header.
    • All fields
    • Any subfield
    • Custom
    text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,*/*;q=0.8
    Method: the user-defined request method.
    None
    GET, POST, PUT, DELETE, and PATCH
    Request Line: Length of a user-defined request line.
    None
    50
    Request: Length of a user-defined request. It includes the request header, request line, and request body.
    None
    None
    ASN: AS number
    • Include
    • Exclude
    • Greater than
    • Less than
    Geolocation
    • Include
    • Exclude
    Known feature crawler
    • Match
    • Mismatch
    • Search engine
    • Scanner
    • Script tool
    • Other
    IP intelligence tag
    NOTE:
    Verify IP intelligence using service logs and context to prevent mistakenly blocking normal traffic caused by limited analysis.
    • Include any value
    • Exclude any value
    Web Attackers
    IP threat level
    Included
    High
    TLS Finger Print
    • Equal to
    • Not equal to
  7. Click OK. You can then view the added precise protection rule in the protection rule list.
    • To modify a rule, click Edit in the row containing the rule.
    • To delete a rule, click Delete in the row containing the rule.
  8. (Optional) Click Modify priorities in batches above the list to change priorities of protection rules in batches.
Protection Effect
If you have configured a precise protection rule as shown in Figure 3 for your domain name, to verify EdgeSec is protecting your website (www.example.com) against the rule:
  1. Clear the browser cache and enter the domain name in the address bar to check whether the website is accessible.
    • If the website is inaccessible, connect the website domain name to EdgeSec by following the instructions in Adding a Website to EdgeSec.
    • If the website is accessible, go to 2.
  2. Clear the browser cache and enter http://www.example.com/admin (or any page containing /admin) in the address bar. Normally, EdgeSec blocks the requests that meet the conditions and returns the block page.
Configuration Example - Disallowing Access Requests from IP Addresses in a Specified Region
Assume that domain name www.example.com has been connected to EdgeSec and you want to disallow only IP addresses in BeijingSingapore, to access the domain name. Perform the following steps:
  1. Add a precise protection rule. Set the Field to Geolocation, Content to BeijingSingapore, and Protective Action to Block.
  2. Enable the precise protection rule.
    Figure 4 Precise Protection configuration area
  3. Clear the browser cache and access http://www.example.com.
    When an access request from IP addresses in BeijingSingapore accesses a page, EdgeSec blocks the access request, as shown in Block page.
    Figure 5 Block page
  4. Go to the EdgeSec console. In the navigation pane on the left, choose Events. View the event on the Events page. You will see that all requests from BeijingSingapore have been blocked.
