Creating a Reference Table to Configure Protection Metrics In Batches
This topic describes how to create a reference table to batch configure protection metrics of a single type, such as Path, User Agent, IP, Params, Cookie, Referer, and Header. A reference table can be referenced by CC attack protection rules and precise protection rules.
Prerequisites
A protected website has been added. For details, see Adding a Website to EdgeSec.
Constraints
A maximum of 100 reference tables can be created.
Application Scenarios
You can use a reference table when you configure protection fields in batches for CC attack protection rules and precise access protection rules.
Procedure
- Log in to the EdgeSec console.
- In the navigation pane on the left, choose Website Settings page is displayed. . The
- In the Policy column of the row containing the domain name, click the number to go to the Policies page.
Figure 1 Website list
- In the CC Attack Protection or Precise Protection configuration box, click Reference Table Management in the upper left corner of the list.
- On the Reference Table Management page, click Add Reference Table.
- In the Add Reference Table dialog box, specify the parameters by referring to Table 1.
Figure 2 Adding a reference table
Table 1 Parameter description Parameter
Description
Example Value
Name
Table name you entered
test
Type
- Path: A URL to be protected, excluding a domain name
- User Agent: A user agent of the scanner to be protected
- IP: Select the IP address of the visitor to be protected, which can be an IPv4 or IPv6 address.
- Params: A request parameter to be protected
- Cookie: A small piece of data to identify web visitors
- Referer: A user-defined request resource.
For example, if the protected path is /admin/xxx and you do not want visitors to access it from www.test.com, set Value to http://www.test.com.
- Header: A user-defined HTTP header
- Method: the user-defined request method.
- ASN: Autonomous system number
Path
Value
Value of the corresponding Type. Wildcards are not allowed.
NOTE:Enter the content and press Enter to confirm the addition. You can repeat the operation to add multiple conditions.
A maximum of 100 conditions can be added.
/buy/phone/
- Click OK. You can then view the added reference table in the reference table list.
Other Operations
- To modify a reference table, click Edit in the row containing the reference table.
- To delete a reference table, click Delete in the row containing the reference table.
Feedback
Was this page helpful?
Chatbot
