Funnel Chart
A funnel chart is applicable to unidirectional analysis of a single process with standard service procedure, long period, and many phases. By comparing service data in each phase of the procedure, you can intuitively find and describe the phase where a problem occurs and make decisions to solve the problem. The funnel chart uses a trapezoidal area to indicate the difference between the service volume of a phase and that of the previous phase.
Checking Funnel Charts
- Log in to the LTS console.
- On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
- Click the Log Analysis tab.
- Enter a query and analysis statement by referring to Using SQL Analysis Syntax, set the time range, and click Search.
- Click
to display the queried data in a funnel chart. Set parameters in the General Settings right pane by referring to Table 1.
Figure 1 Funnel chart
Feedback
Was this page helpful?
Chatbot
