Updated on 2025-09-07 GMT+08:00
Map
A map is used as the background to display geographic data in different colors and marks. Maps provided by LTS include the China map and the world map. After you use specific functions (ip_to_province for the China map and ip_to_country for the world map) in query and analysis statements, LTS displays analysis results on a map.
A map contains the following elements:
  • Map canvas
  • Color block
Checking Maps
  1. Log in to the LTS console.
  2. On the Log Management page, select the target log group and log stream. The log stream details page is displayed.
  3. Click the Log Analysis tab.
  4. Enter a query and analysis statement by referring to Using SQL Analysis Syntax, set the time range, and click Search.
  5. Click to display the queried data in a map. Set parameters in the General Settings right pane by referring to Table 1.
    Figure 1 Map
    Table 1 Map parameters
    Parameter
    Description
    Map Type
    Sets the region range displayed on the map, including the provincial map of China and the world map.
    Province
    If the map type is a provincial map of China, this field indicates a specific province, for example, Zhejiang province.
    Country/Region
    If the map type is a world map, the value of this field is a specific country, for example, China.
    Data Column
    Select the field whose value needs to be displayed.
    Title Font Size
    Sets the font size of the chart title.
